[GiDlist] one question about the batch file ( .pro)
Posted: Wed Mar 13, 2002 2:18 pm
by Yuyi Zhang
I want to create the geometry of my model in a batch file (.pro). How could
I use
the existing points to create lines, instead of creating new points? I
noticed that
at the beginning of your examples, you set ' utilities variable
createalwaynewpoint 1 '
Is this the command I should change?
Thanks.
Yuyi
Posted: Wed Mar 13, 2002 3:45 pm
Before pick a point, select "Join" to pick old points (pick in screen or write your label number) or "NoJoin" to create a new point.
For example
escape escape escape Geometry create point
0.0 0.0 0.0
1.0 0.0 0.0
escape
escape escape escape Geometry create Line
Join
1
2
escape
The variable CreateAlwaysNewPoint is set to 1 in some batchs to create always a new point ,over another in the same location, without user confirmation (see Help for Utilities-Preferences-General)
Create new point: It alters the way how the points are entered in GiD
(see section Point definition). Options are:
Always: If trying to create a new point in the vicinity of an existing one, the
new point is always created.
Ask: If trying to create a new point in the vicinity of an existing one, GiD asks
the user whether to make use of the existing point or create a new one.
Never: Only allows to select existing points. It can be changed
interactively when in creation point mode by setting No join until all
points are entered.
Sent: Friday, March 08, 2002 7:13 PM
Subject: [GiDlist] one question about the batch file ( .pro)
I use
noticed that
Thanks.
Yuyi
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020313/f6d049e5/attachment.htm
[GiDlist] Question for Stress Post processing
Posted: Wed Mar 13, 2002 7:23 pm
by Changho Desk
Hello, All
I'm trying to postprocess for my Gauss stresses. My model consists of 4 node quadrilateral element and Linear Beam element. From my solver module, I'm only extracting the stresses from Gauss points of quadrlateral elements. Can we do this without the result stresses from other elements? If I can, could you cehck my header of *.flavia.res. I appreciate your help
My file is
Suppose element 1~30 is beam(linear) element. So I don't extract the results for these.
GaussPoints "Quads" ElemType Quadrilateral
Number of Gauss Points: 4
Natural Coordinates: Internal
End gausspoints
Gauss_stresscho 1 0.02 2 2 1 "Quads"
Sxx
Syy
Sxy
31 -0.576695 -0.103969 3.37268e-307
-0.580054 -0.113903 3.37268e-307
-0.745871 -0.184967 3.37268e-307
-0.741706 -0.174688 3.37268e-307
32 -0.561898 -0.186164 3.37268e-307
-0.567976 -0.200322 3.37268e-307
-0.567189 -0.199984 3.37268e-307
-0.561115 -0.185828 3.37268e-307
33 -0.573824 -0.221463 3.37268e-307
-0.575536 -0.225585 3.37268e-307
-0.578338 -0.226786 3.37268e-307
-0.576612 -0.222658 3.37268e-307
34 -0.57852 -0.237674 3.37268e-307
-0.57846 -0.237606 3.37268e-307
-0.57963 -0.238108 3.37268e-307
-0.579684 -0.238172 3.37268e-307
Changho from Univ. of Washington
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020313/922c3568/attachment.htm
Posted: Wed Mar 13, 2002 10:40 pm
You can write results only for some quadrilateral gauss points.
Note: to use the new postprocess result format, GiD version 6.1.4b or higher is required.
Sample of corrected file *.flavia.res (results for a 2D symmetric matrix: Sxx,Syy,Sxy)
GiD Post Results File 1.0
End gausspoints
Result "Gauss_stress" "Load Analysis" 1 Matrix OnGaussPoints "Quads"
Values
End Values
Sent: Wednesday, March 13, 2002 7:21 PM
Subject: [GiDlist] Question for Stress Post processing
Hello, All
My file is
End gausspoints
Sxx
Syy
Sxy
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020313/a6f8f118/attachment.htm
Posted: Wed Mar 13, 2002 11:55 pm
by Changho Desk
Thank you for your help
However, I'm using version 6.1.2 and it' not compatible with new result file format.
Could you help me in version 6.1.2 format for stresses in the gauss points?
Sent: Wednesday, March 13, 2002 1:52 PM
Subject: Re: [GiDlist] Question for Stress Post processing
End gausspoints
Values
End Values
Hello, All
My file is
End gausspoints
Sxx
Syy
Sxy
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020313/84ac0be0/attachment.htm
Posted: Thu Mar 14, 2002 12:18 pm
You can download a more recente version,for example, the beta version 6.2.0d
from the GiD web page http://gid.cimne.upc.es (download beta versions)
Your GiD 6 password is also valid for this beta version
To try to write the gauss results in the old format, see the help (prosprocess data files)
Sent: Wednesday, March 13, 2002 11:53 PM
End gausspoints
Values
End Values
Hello, All
My file is
End gausspoints
Sxx
Syy
Sxy
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020314/23be831c/attachment.htm
