Hi Enrique,
In this mail you give some information about the side of elements. I am
interested in choosing side of element. I tried to figure out how I can do
that but I always encounter a problem choosing the side on the mesh figure.
Actually I want to get an output which contains side and its element. I could
do the sets form nodes and elements using condition tool. But i could not get
the side set from there.
Can I choose the element sides on the mesh figure in the GID interface to
define sets or any other conditions on it.
----- Forwarded message from Enrique Escolano escolano at cimne.upc.es -----
Date: Mon, 10 Nov 2003 11:57:34 +0100
Subject: Re: [GiDlist] is possible to get the every side of ele
This face elements are implicitly defined by the element connectivities, not
exists explicit inside GiD
The implicit GiD local numeration of the element faces are:
Triangle: 12 23 31
Quadrilateral: 12 23 34 41
Tetrahedra: 123 243 341 421
Hexahedra: 1234 1562 2673 3784 1485 5876
Your code must enumerate this faces, for example, if your code names A,B,C,
the three faces of a triangle, then can use some as:TRIANGLE FACES:
Face A: *ElemsConec(1,int) *ElemsConec(2,int)
Face B: *ElemsConec(2,int) *ElemsConec(3,int)
Face C: *ElemsConec(3,int) *ElemsConec(1,int)
Also, if you have a condition over a face of a triangle (a edge), you can
identify the implicit face A B or C with globalnodes
*Set elems(triangle)
*Set Cond Line_Face_Load *elems
*loop elems *OnlyInCond
*if(GlobalNodes(1,int)==ElemsConec(1,int))
FACE A
*elseif(GlobalNodes(1,int)==ElemsConec(2,int))
FACE B
*else
FACE C
*endif
*end elems
Or more simple, using the localnodes command
*if(LocalNodes(1,int)==1)
FACE A
*elseif(LocalNodes(1,int)==2)
FACE B
*else
FACE C
*endif
*end elems
Sent: Saturday, November 08, 2003 10:39 AM
Subject: [GiDlist] is possible to get the every side of ele
hi,GID group,
when i use GID, i want to get the information about the side of each
elements. By the command GlobalNodes, after I applied some condition to some
element, I only can get the out-side face of element. are there any way to get
the every side of each element? include the side of internal element. for
example, I want to get the all out-side face of one layer element. how can i
do?
regards
----- End forwarded message -----
Url: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031111/0a00e101/attachment.txt
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031111/0a00e101/attachment.htm
Type: image/gif
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031111/0a00e101/attachment.gif
Fwd: Re: [GiDlist] is possible to get the every side of ele
I don't understand your question.
You can define in your problemtype a condition over face elements, named for example "Line_Face_Load"
(read GiD help about the conditions file), for example
NUMBER: 1 CONDITION: Line_Face_Load
CONDTYPE: over lines
QUESTION:Pressure
VALUE: 0.0
END CONDITION
And then use *globalnodes to list the ordered nodes of this face:
FACE: *GlobalNodes PRESSURE: *Cond(Pressure,real)
*end elems
Sent: Tuesday, November 11, 2003 2:22 PM
Subject: Fwd: Re: [GiDlist] is possible to get the every side of ele
Hi Enrique,
Triangle: 12 23 31
FACE A
FACE B
*else
FACE C
*endif
*end elems
FACE A
FACE B
*else
FACE C
*endif
*end elems
hi,GID group,
do?
regards
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031111/6cc46dd7/attachment.htm
QUESTION:Pressure
VALUE: 0.0
END CONDITION
*end elems
Hi Enrique,
Triangle: 12 23 31
FACE A
FACE B
*else
FACE C
*endif
*end elems
FACE A
FACE B
*else
FACE C
*endif
*end elems
hi,GID group,
do?
regards
Hi Enrique,
For an element with two free edges (sides) I am not able to select the
side I want. There seems to be an arbitrary or default procedure according
to which GID assignes conditions over sides.
See the attached mesh: element 7 has free edges with nodes 1,3,5 and 1,2,4.
Can I select these edges independently? If yes how?
QUESTION:Pressure
VALUE: 0.0
END CONDITION
*end elems
Hi Enrique,
could
get
not
Triangle: 12 23 31
FACE A
FACE B
*else
FACE C
*endif
*end elems
FACE A
FACE B
*else
FACE C
*endif
*end elems
hi,GID group,
some
get
i
do?
regards
Type: image/pjpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031112/9cdf7179/attachment.bin
QUESTION:Pressure
VALUE: 0.0
END CONDITION
*end elems
Hi Enrique,
could
get
not
Triangle: 12 23 31
FACE A
FACE B
*else
FACE C
*endif
*end elems
FACE A
FACE B
*else
FACE C
*endif
*end elems
hi,GID group,
some
get
i
do?
regards
Type: image/pjpeg
Do you apply the condition directly over the mesh?
In this case, it's not possible now to assign the condition to a edge only,
automatically select all boundary edges.
In general, it's unrecommended to directly assign conditions over the mesh,
it's best to assign it over the geometric entities, and
then generate the mesh (the conditions are atomatically transferred to the
mesh)
You must define a condition : over lines, over face elements, and apply it
to the desired lines.
Sent: Wednesday, November 12, 2003 5:56 PM
Subject: Re: Re: [GiDlist] is possible to get the every side of ele
Hi Enrique,
1,2,4.
for
QUESTION:Pressure
VALUE: 0.0
END CONDITION
*end elems
Hi Enrique,
am
can do
figure.
I
could
not
get
interface to
connectivities,
not
Triangle: 12 23 31
A,B,C,
can
FACE A
FACE B
*else
FACE C
*endif
*end elems
FACE A
FACE B
*else
FACE C
*endif
*end elems
hi,GID group,
to
some
way to
get
for
can
i
do?
regards
mesh)
Hi Enrique,
1,2,4.
for
QUESTION:Pressure
VALUE: 0.0
END CONDITION
*end elems
Hi Enrique,
am
can do
figure.
I
could
not
get
interface to
connectivities,
not
Triangle: 12 23 31
A,B,C,
can
FACE A
FACE B
*else
FACE C
*endif
*end elems
FACE A
FACE B
*else
FACE C
*endif
*end elems
hi,GID group,
to
some
way to
get
for
can
i
do?
regards
