Hello Mark and gidlist users.
I send this answer to the gidlist, because this topic is very little explained in the current documentation,
and it can be of interest for other users. I attach also a small problemtype to show the "GiD units" use.
To create a problemtype with GiD units, can create a file named problemetype.uni
For example, in a previous mail, Rama Karve want to obtain the output lengths in centimeters.
Then can define a system, named user-1 with the desired output units (cm, kp/cm^2) for your magnitudes (length, pressure, etc)
This is a sample of problemetype.uni
USER DEFINED: DISABLED
USE BASE SYSTEMS: DISABLED
BEGIN TABLE
length : m { basic }, 100 cm , 1.0e+3 mm
strength : N { basic }, kg*m/s^2 ,1.0e-1 kp
pressure : Pa { basic }, N/m^2 ,1.0e-5 kp/cm^2
weight : N/m^3 { basic }, 1.0e-4 ton/m^3 , 1.0e-1 kp/m^3 , 1.0e-7 kp/cm^3
END
begin system(user-1)
length : cm
strength : kp
pressure : kp/cm^2
weight : kp/cm^3
end
And this is your explanation:
This disable the user option to change the system units at run time (from the Data-Units window)
Is to ignore the default (international, or others ) GiD unit systems (defined inside /scripts/uni.gid.),
and only show the problemtype defined "user-1" system
BEGIN TABLE
length : m , 100 cm , 1.0e+3 mm
strength : N , kg*m/s^2 ,1.0e-1 kp
pressure : Pa , N/m^2 ,1.0e-5 kp/cm^2
weight : N/m^3 , 1.0e-4 ton/m^3 , 1.0e-1 kp/m^3 , 1.0e-7 kp/cm^3
END
This is the scale factor between the first basic unit, and other units for a magnitud.
For example 1m=100 cm=1e3 mm, ...
In fact, it's not necessary this definition if the desired units also exists in /scripts/uni.gid
(currently uni.gid has a small number of units, but it can be completed for next versions)
length : cm
strength : kp
pressure : kp/cm^2
weight : kp/cm^3
end
Defines the system units used as *.bas output for node coodinates (length) or other material/contition fields with units.
It's possible to define several systems, and the user can select at run-time the desired one.
This is a problemtype.mat material file, with a material
NUMBER: 1 MATERIAL: Steel
QUESTION: YOUNG:#UNITS#
VALUE: 2.1e11kp/cm^2
IMAGE: young.gif
HELP: Elastic modulus
QUESTION: POISSON
VALUE: 0.3
HELP: Poisson modulus
QUESTION: WEIGHT#UNITS#
VALUE: 78000kp/cm^3
HELP: Only used if self-weight in general data is enabled
QUESTION: THICKNESS#UNITS#
VALUE: 1.0m
HELP: Only used for plane stress (1.0 for plane strain)
END MATERIAL
Note that some fields have #UNITS# after the question name (YOUNG:#UNITS#),
and the default value has the also the unit symbol (2.1e11kp/cm^2), whitout spaces between value and unit.
The field can be filled whit the more "user-friendly" unit (see the drop-down menu for the thickness field) and
after the output in the calculation file is always in the expected system unit.
Inside the problemtype.bas ,it exists some commands related to units.
SYSTEM OUTPUT UNITS
LENGTH: *Units(LENGTH)
PRESSURE: *Units(PRESSURE)
Conversion factors:
1 *Units(LENGTH) is equal to *FactorUnit(LENGTH) *BasicUnit(LENGTH)
1 *Units(PRESSURE) is equal to *FactorUnit(PRESSURE) *BasicUnit(PRESSURE)
NODES
*loop nodes
*nodesnum *NodesCoord
*end
MATERIALS
*loop materials
*matprop(YOUNG,real) *matprop(POISSON,real) *matprop(WEIGHT,real) *matprop(THICKNESS,real)
*end materials
The user must declare the model length unit, from the Data-Unit window. (m, cm or mm in this sample)
The *NodesCoord command writes the coordinates always in cm (the selected user-1 system length unit)
*matprop(YOUNG,real) write this field always in kp/cm2 (the pressure system unit).
Other related commands are for example:
*Units(LENGTH) : return the current system unit (the output unit obtained in the bas file for the "LENGTH" magnitude)
*BasicUnit(LENGTH) : return the basic unit (the first list item in BEGIN TABLE for the this magnitude)
*FactorUnit(LENGTH) : Is the factor to multiply by BasicUnit to convert a magnitude to the system Unit.
Note: The units are a concept now "under develop", the last GiD versions have a bug when the user change the model unit,
the length factor is cached to speed the output, and because this bug it's not updated.
This bug is corrected for the next 7.4.5b beta version.
For next versions it's also planned to allow units in result files, and show/select this units in postprocess.
To: escolano at cimne.upc.es
Sent: Thursday, November 06, 2003 10:44 AM
Subject: RE: GiD units
Dear Enrique
I'm confused? I thought both Philippe & myself were talking about the same
method I just gave an example of how it would be done?
If there is a better way please let me know.
Mark
-----Original Message-----
Sent: 05 November 2003 20:51
Subject: Re: [GiDlist] Units conversion
The "Mark Smith" answer is a mode to solve the problem without use the "GiD
concept of units", the problemtype defines a general data to declare the
current unit, and the bas file check this value and aply the apropiate
factor to the coordinates.
In this case, GiD internally unknown the significate of the general data
unit field.
The "Philippe" approach instead uses the GiD unit concept: Then the user
declare for GiD the model unit from the Data-Unit menu, and GiD write the
coordinates in the bas file in the reference unit.
Not only the model can have unit, also a condition or material field can
have your unit, and GiD automatically translate the input values in the more
user-friendly unit (selected from a listbox) to the reference unit.
See help on Customization-Configuration Files-Unit System file
Sent: Tuesday, November 04, 2003 11:08 PM
Subject: [GiDlist] Units conversion
The problem I have is this - My solver assumes that the geometry has been
defined in centimeters. However, I want to allow the user to define the
geometry in some other unit if they want to, and then in some way convert
the units before feeding the file to the solver.
For example, if the user wants to define his geometry in mm, and defines a
line between points (-5, 0, 0) to (5, 0, 0) the coordinates I want to
write
to the input file are (-0.5, 0, 0) and (0.5, 0, 0).
Is there a quick way to do this in GiD?
Rama Karve
Incoming mail is certified Virus Free.
Version: 6.0.528 / Virus Database: 324 - Release Date: 16/10/2003
the error.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031106/a2acd641/attachment.htm
Name: not available
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031106/a2acd641/attachment.png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031106/a2acd641/attachment.bin
[GiDlist] Re: GiD units
