I have my fields points in volume as a function of (x,y,z). What I would
like it to have is the iso-surface that represent certain field magnitude
in GID. Could you please give some hints.
I also would like to visualizes these points in vector form at specific
plane such as (x,y,0) in GID. Could you please give some hints.
Khaled Obeidat
Research Engineer
EMAG Technologies, Inc.
www.emagtechnologies.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031015/47b5085c/attachment.htm
[GiDlist] Iso-surfaces and vector filed
About your two questions:
!) I have my fields points in volume as a function of (x,y,z). What I would like it to have is the iso-surface that represent certain field magnitude in GID. Could you please give some hints.
Set for example visualization style to Boundaries,
and set
Options-IsoSurfaces-Display Style-Body
Then
View Results-Isosurfaces ...
2) I also would like to visualizes these points in vector form at specific plane such as (x,y,0) in GID. Could you please give some hints.
Can create a cut from this plane (Do Cuts-Cut Plane ... )
Some options are availables for sets, but not for cuts. Can convert cuts to sets with DoCuts-Convert cuts to surface sets
Sent: Wednesday, October 15, 2003 11:12 PM
Subject: [GiDlist] Iso-surfaces and vector filed
Khaled Obeidat
Research Engineer
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031017/063eb29d/attachment.htm
and set
Then
Khaled Obeidat
Research Engineer
