[GiDlist] Some problems with Gauss point results
Posted: Mon Oct 13, 2003 9:25 am
by Andrea Calaon
Hello everyone,
I have some problems trying to display gauss point based scalar
results.
I just tried to represent a non linear scalar field on only one
triangular element with 6 gauss points, here is the example.
Can you see the problem?
Do you have any suggestion?
Thanks in advance
Result file:
_____________________________________
GiD Post Results File 1.0
GaussPoints "Board" ElemType Triangle
Number Of Gauss Points: 6
Natural Coordinates: internal
end gausspoints
GaussPoints "Board2" ElemType Triangle
Number Of Gauss Points: 3
end gausspoints
Result "Potential" "Load Analysis" 1 Scalar OnGaussPoints
"Board"
Values
1 0.1
0.1
0.1
0.5
0.5
0.5
end values
___________________________________________________
_______
Mesh file:
_______
MESH "SurfaceSet 11" dimension 3 ElemType Triangle Nnode 3
Coordinates
1 1 0 0
2 0 0 0
3 0 1 0
end coordinates
Elements
1 2 1 3 11
end elements
________
Andrea Calaon
Ashurst Lodge, Ashurst
Southampton, Hampshire
SO40 7AA, UK
Fax office: +44 23 80 292 853
Mobile: +44 7766 488 225
E-mail: andrea at beasy.com
Posted: Fri Oct 17, 2003 5:51 pm
by Miguel A. de Riera Pasenau
The problem is that gid extrapolates de gauss point values to the nodes
and the draws the triangle.
As the triangle has only three nodes, it draws a triangle
with a constant value, i.e. only one color.
You can select 'Display Style-points' and you'll get coloured
spheres located at the gauss points with their values.
You can also enter 6-noded triangles to see the variation inside
the triangle, but i've done already and found that, with the current
version, it does the same as with the 3-noded ones.
i've fix it and will be available for the next version.
Andrea Calaon wrote:
Hello everyone,
results.
Thanks in advance
Result file:
end gausspoints
end gausspoints
"Board"
Values
1 0.1
0.1
0.1
0.5
0.5
0.5
end values
_______
Mesh file:
_______
Coordinates
1 1 0 0
2 0 0 0
3 0 1 0
end coordinates
Elements
1 2 1 3 11
end elements
________
Andrea Calaon
SO40 7AA, UK
