[GiDlist] Surface Coordinates
Posted: Tue Oct 07, 2003 9:22 pm
by Khaled Obeidat
Is there a way to find the points that consist a surface directly ?
Best Regards
Khaled Obeidat
Research Engineer
EMAG Technologies, Inc.
www.emagtechnologies.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031007/06d2d8f9/attachment.htm
Posted: Tue Oct 07, 2003 9:37 pm
by Philippe Bouchilloux
Hello:
If you cannot list the points directly because the geometry is too complex,
then maybe you can create a layer, send the surface into that layer (with
lower entities), turn off all the layers except this new one, and then list
the points (Utility | List | Points) from there.
I don't think there is a simple hierarchical link from higher entities
(surface) to lower (points), although there is one (Utilities | Draw
higher) from lower entities to higher ones.
Hope this helps.
Philippe
Magsoft Corporation
Tel: 518-271-1352
Cell: 518-365-0421 (direct)
www.magsoft-flux.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031007/a1036e2c/attachment.htm
