[GiDlist] create geometry mdoel thorugh batch file
Steven Xu
Post by Steven Xu »
Hi dear GID users,
I wonder whether I can create a 3D geometry model through a batch file which
contains:
- a list of points (x y z coordinates)
- a list of polygons/surfaces (each polygon lists its
points/vertices)
- a list of volumes (each volume lists its polygons/surfaces)
thanks, steven
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030908/19b665d8/attachment.htm
Post by Enrique Escolano »
If you know the identifiers to be create for each entity, you can write a batch file as:
escape escape escape escape geometry create point
x1 y1 z1 -create the point number 1 (if not exists more points)
xn yn zn -create the point number n
escape
escape escape escape escape geometry create line join
idp1 idp2 escape
idpt1 idpt2 escape
escape escape escape escape geometry create NurbsSurface
idln1 idln2 ... idlnN
escape escape escape escape geometry create Volume
idsurf1 idsurf2 ... idsurfN
Sent: Monday, September 08, 2003 4:57 PM
Subject: [GiDlist] create geometry mdoel thorugh batch file
Hi dear GID users,
I wonder whether I can create a 3D geometry model through a batch file which contains:
- a list of polygons/surfaces (each polygon lists its points/vertices)
thanks, steven
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030909/ca3999d8/attachment.htm
Steven Xu
Post by Steven Xu »
Thanks a lot, Enrique.
Just to clarify, so I should do
Create points -- create lines -- create NurrbsSurfaces --
create volumes
Rather than try
Create points -- create NurrbsSurfaces -- create volumes
Thanks again.
Steven Xu
-----Original Message-----
[mailto:gidlist-admin at gatxan.cimne.upc.es] On Behalf Of Enrique Escolano
Sent: Tuesday, September 09, 2003 9:41 AM
Subject: Re: [GiDlist] create geometry mdoel thorugh batch file
batch file as:
escape
idp1 idp2 escape
idpt1 idpt2 escape
Hi dear GID users,
contains:
points/vertices)
thanks, steven
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030909/e478453d/attachment.htm
Must create
points à lines à NurbsSurfaces à volumes
Sent: Tuesday, September 09, 2003 7:12 PM
Subject: RE: [GiDlist] create geometry mdoel thorugh batch file
Create points à create lines à create NurrbsSurfaces à create volumes
Rather than try
Create points à create NurrbsSurfaces à create volumes
Thanks again.
Steven Xu
From: gidlist-admin at gatxan.cimne.upc.es [mailto:gidlist-admin at gatxan.cimne.upc.es] On Behalf Of Enrique Escolano
escape
idp1 idp2 escape
idpt1 idpt2 escape
Hi dear GID users,
thanks, steven
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030910/b25e3c00/attachment.htm
