[GiDlist] post-process file
Posted: Mon Sep 01, 2003 3:12 pm
by kalo81 at virgilio.it
Dear GiD Team,
I have to configure my solver to create the file to be post-processing.
Could I consider values only on nodes without consider internal gausspoints?
If so, is it ok this configuration?:
GiD post results File 1.0
Result "Electric field" "load analisys" step_value Vector onnodes
Componentnames "x", "y", "Z"
Value
end value
Calogero
PS: can you write me an example to teach in a better way the meaning of
"step_value"?
Posted: Wed Sep 03, 2003 10:23 am
Your result file seems ok, with some comments: instead Value, must write the
plural Values
The step_value must be a integer or real number (represents a time step, or
a step number)
for example:
GiD Post Results File 1.0
Result "Displacements" "movement" 0.1 Vector OnNodes
Values
7 1.0 0.0 0.0
end values
Result "Displacements" "movement" 0.2 Vector OnNodes
Values
7 1.5 -0.2 0.0
end values
Result "Displacements" "movement" 0.3 Vector OnNodes
Values
7 2.0 -0.7 0.0
end values
To: "GIDLIST" gidlist at gatxan.cimne.upc.es
Sent: Monday, September 01, 2003 4:11 PM
Subject: [GiDlist] post-process file
Dear GiD Team,
gausspoints?
Value
end value
Calogero
"step_value"?
