[GiDlist] (no subject)
Posted: Mon Aug 04, 2003 2:26 pm
by chen guangjing
Hola, Gidlist
Once again I met a problem with GID 7.2: when I draw a line, the two
endpoints are very small and not clear to see. Somebody from Gidlist has
told me before that I should change the setting of the display, but I
forget which option I should make.
Could you please tell me once again?
Thanks!
Chen Guangjing
Posted: Tue Aug 05, 2003 11:57 am
by Ramon Ribó
Check:
http://gid.cimne.upc.es/support/faq_8.subst
De:
gidlist-admin at gatxan.cimne.upc.es
[mailto:
gidlist-admin at gatxan.cimne.upc.es] En nombre de chen guangjing
Enviado el: lunes, 04 de agosto de 2003 15:25
Para:
Asunto: [GiDlist] (no subject)
Hola, Gidlist
forget which option I should make. Could you please tell me once again?
Thanks!
Chen Guangjing
Posted: Mon Aug 11, 2003 2:08 pm
Hello Chen.
Your problem was solved by using a new version of the drivers for the graphics card. (see your own message: 13 feb 2003)
Note: Can read any old gidlist message at:
http://www.gidhome.com/pipermail/gidlist/
chen.guangjing at upc.es
To:
Sent: Monday, August 04, 2003 3:24 PM
Hola, Gidlist
Thanks!
Chen Guangjing
URL:
http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030811/6bc199af/attachment.htm
