[GiDlist] inaccurate postprocessing with given Gauss points
Posted: Mon Jun 30, 2003 12:45 am
by Andres Peratta
When postprocessing scalar results with "given" gauss points
I found out that the visualization becomes quite inaccurate.
For example Contour_fill and Contour_lines options, dont' work properly.
It seems that the defined coordinates of the gauss points should not have
more than 5 decimal figures,
otherwise the given coordinates in the .res file are not read properly
by GID.
To see what is going on, you can try the following example in which
a scalar field
u(x,y) = x
is visualized in a single unitary triangular element with 6 gauss points
located at the following coordinates :
a = 1/6, b = 2/3, c = 5/12, d = 1/6
( a, a) ( b, a) ( a, b) ( c, d) ( c, c) ( d, c)
( see the attached .res file in which I used different precisions to
represent the fractional
numbers 1/6, 2/3 and 5/12 , and see what happens when contour_lines
or contour_fill options are selected )
The main problem is that if I want to increase the precision of the
given coordinates,
beyond 5 figures the result is completely unpredictable,
and if I keep 5 or less figures, the visualization does not reflect the
real scalar field.
Is there any solution ?
Has anyone faced this problem before ?
Thanks for your help.
best regards,
Andres
Andres B. Peratta
Wessex Institute of Technology
Email: andres at wessex.ac.uk
Tel: +44 (0)238 029 3223
Fax: +44 (0)238 029 2853
Ashurst Lodge
Ashurst
Southampton (SO40-7AA)
UK
An embedded and charset-unspecified text was scrubbed...
Url: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030630/33570632/attachment.txt
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030630/33570632/attachment.obj
Type: model/mesh
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030630/33570632/attachment.msh
Type: model/mesh
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030630/33570632/attachment-0001.msh
Posted: Tue Jul 01, 2003 9:53 am
by Miguel A. de Riera Pasenau
Yes, there was a problem with inverting a matrix when zeros appeared
on the diagonal. With 0.16667 there was no problem, but with 0.1666666666666666667.
i think i will prepare a new beta this week with this problem solved.
by GID.
a scalar field
u(x,y) = x
given coordinates,
real scalar field.
best regards,
Andres
Andres B. Peratta
Ashurst Lodge
Ashurst
UK
Gid Post Results File 1.0
GaussPoints "gauss1" Elemtype Triangle
Number Of Gauss Points: 6
Natural Coordinates: Given
0.16667 0.16667
0.66667 0.16667
0.16667 0.66667
0.41667 0.16667
0.41667 0.41667
0.16667 0.41667
End GaussPoints
GaussPoints "gauss2" Elemtype Triangle
0.166666666667 0.166666666667
0.666666666667 0.166666666667
0.166666666667 0.666666666667
0.416666666667 0.166666666667
0.416666666667 0.416666666667
0.166666666667 0.416666666667
End GaussPoints
GaussPoints "gauss3" Elemtype Triangle
Natural Coordinates: Internal
End GaussPoints
Result "uf" "Convergency" 2.0000E+00 scalar OnGaussPoints "gauss1"
Values
1 0.16667
0.16667
0.66667
0.16667
0.41667
0.41667
End Values
Result "uf" "Convergency" 2.0000E+00 scalar OnGaussPoints "gauss2"
Values
1 0.16667
0.16667
0.66667
0.16667
0.41667
0.41667
End Values
Result "uf" "Convergency" 2.0000E+00 scalar OnGaussPoints "gauss3"
Values
1 0.16667
0.16667
0.66667
0.16667
0.41667
0.41667
End Values
testgp.geo Type: unspecified type (application/octet-stream)
Encoding: base64
testgp.msh Type: model/mesh
Encoding: quoted-printable
testgp.flavia.msh Type: model/mesh
Encoding: 7bit
