[GiDlist] Re: GiDlist digest, Vol 1 #408 - 6 msgs
Posted: Mon Jun 23, 2003 4:45 pm
About the mesh simmetry in a simmetric geometry, as unstructured mesh
is an heuristic algorithm, you can never guarantee that you will obtain
the same mesh although the geometry is simmetric. You cannot even
guarantee that you will obtain the same mesh on two runs of the mesher
in the same geometry. But good analysis codes do not depend on the mesh,
do they?
I am not using an unstructured mesh, I am using a structured mesh over a
plane-symmetric and an axisymmetric geometry, and the resulting mesh is
still unsymmetric. I can send the input file for anyone to verify this.
While the analysis program results do not depend on the mesh for a good
analysis code (as is the case here), a truly "good" analysis code will
take advantage of symmetry and axisymmetry and realize a huge time savings
(a factor of 5 for our program with axisymmetry recognized). A good
preprocessor will give symmetric meshes for structured meshing over
symmetric geometry.
do they?
symmetric geometry.
