Thanks for the reply,
I use a mix from woody, sarge and a little bit of unstable. I'm planning an
update to sarge.
Unless the statically compiled installer it gives me a segmentation fault.
The internet retrieve also has the segmentation fault. This evening I can
investigate futher.
Should I compile the problem types for Linux? I tried it with the cmas2d,
without succes.
Johnny
On Mon, 12 May 2003 08:55:34 +0200, you wrote:
it uses glibc 2.2.
GiD is compiled statically, and the installator too, so
no external libraries are needed.
There is a dynamic version:
ftp://www.gidhome.com/pub/gid_adds/Linux/gid7.3b-dyn.tar.gz
to take advantage of the graphics acceleraiton provided by
the X server.
Which version of Debian are you using?
To do any calculation you have to install a simulation code,
for instance Rambshell, Tdyn, caltep, emant, or any other.
take a look at http://www.gidhome.com/gidplus/
or into the option menu 'Data-Problem type-Internet retrieve'.
Johnny Geling wrote:
I installed GID on a Linux box (Debian, woody with sarge and unstable
parts)
What Glibc version needs GID? And what other versions of libraries are
required?
The problems I have:
- instal verion not working: segmentation fault
- I cannot do any calculation: cannot find problemtype.dat file and
when
it can find it it cannot open or run. Because I'm not at that computer I
cannot phrase the exact error.
- retrieve problem type list causes a segmentation fault.
Any help is appriciated.
Johnny
Miguel A. Pasenau de Riera miguel at cimne.upc.es
Re: [GiDlist] glibc version?
The "internet retrieve" problemtypes, at this moment, only includes the
Win32 compiled executable.
Are not compiled for Linux. To obtain a Linux/Unix version of Ramseries of
Tdyn contact Compass
web page: http://www.compassis.com
What's the problem with cmas2d? It exists some problem to compile cmas2d.c
to cmas2d?
Must also change cmas2d.unix.bat to start this executable: $3/cmas2d $2/$1
(and set the permission execution flag of cmas2d with chmod +x)
Sent: Monday, May 12, 2003 2:15 PM
Subject: Re: [GiDlist] glibc version?
an
update to sarge.
investigate futher.
without succes.
Johnny
it uses glibc 2.2.
the X server.
parts)
required?
when
I
Johnny
to cmas2d?
an
update to sarge.
investigate futher.
without succes.
Johnny
it uses glibc 2.2.
the X server.
parts)
required?
when
I
Johnny
