[GiDlist] Saving informations about the project
Posted: Mon May 12, 2003 9:33 am
by Mihai TEODORESCU
Hello and thank you for your advise.
I think that is the only way to achive my goals. Initialy I thought that
the only information i needed was the surface Id. But I found no way to
extract the elements (3D elements) that have one face belonging to a
given surface. (maybe there is one i didn't find).
So the second way would be to use conditions. But I'm sure how can I
make a dialog window where i can assign two conditions, one for the
master surface and the second for the slave surface. Can you give me
some indications in this way?
Thank you,
Mihai TEODORESCU
Tel: 05.49.25.40.63
Email: mihai.teodorescu at prevost-industries.com
Posted: Mon May 12, 2003 11:27 am
1) You can store the surface element's source, inside autocalculated field of a condition.
QUESTION: Surface_number#FUNC#(NumEntity)
VALUE: 0
STATE: hiddden
2) To learn to make a dialog window, read the chapter 3 of this advanced course documentation:
http://www.gidhome.com/2002/material_courses.subst
To select GiD entities from Tcl/Tk, can use this user procedure (defined inside /scripts/dev_kit.tcl)
proc GidUtils::PickEntities { type selectmode }
# It returns the enties identifier numbers (for example 1 3 5:8 represents 1 3 5 6 7 8)
# type can be "Points" "Lines" "Surfaces" "Volumes" "Nodes" or "Elements"
# selectmode can be "single" or "multiple"
For example:
set surf [::GidUtils::PickEntities Surfaces single]
The file dev_kit.tcl contain some GiD-Tcl developer utilities (to be documented)
From: "Mihai TEODORESCU" mihai.teodorescu at prevost-industries.com
Sent: Monday, May 12, 2003 10:31 AM
Subject: RE: [GiDlist] Saving informations about the project
Thank you,
Mihai TEODORESCU
Tel: 05.49.25.40.63
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030512/7e3221e1/attachment.htm
