if you want only to define the results over points you'll need 'point elements'
like the attached example.
The results/elements will be drawn as big points.
Use the Options-Geometry-Point options...' window to change its size, to
switch between the 'quick' look and the 'nice' look, and change its 'detail' level.
Miguel A. Pasenau de Riera
miguel at cimne.upc.es http://gid.cimne.upc.es
MESH "puntito" dimension 3 Elemtype Point Nnode 1
Coordinates
1 0.0 0.0 0.0
End Coordinates
Elements
1 1
End Elements
MESH "origen-fin" dimension 3 Elemtype Point Nnode 1
Coordinates
2 0.0 0.0 0.0
3 2.0 0.0 0.0
End Coordinates
Elements
2 2
3 3
End Elements
GiD Post Results File 1.0
Result "Displacement" "Wave" 1 Vector OnNodes
Values
1 0.2 0.309 0
2 0 0 0
3 0 0 0
End values
Result "Displacement" "Wave" 2 Vector OnNodes
Values
1 0.4 0.5878 0
2 0 0 0
3 0 0 0
End values
Result "Displacement" "Wave" 3 Vector OnNodes
Values
1 0.6 0.809 0
2 0 0 0
3 0 0 0
End values
Result "Displacement" "Wave" 4 Vector OnNodes
Values
1 0.8 0.9511 0
2 0 0 0
3 0 0 0
End values
Result "Displacement" "Wave" 5 Vector OnNodes
Values
1 1 1 0
2 0 0 0
3 0 0 0
End values
Result "Displacement" "Wave" 6 Vector OnNodes
Values
1 1.2 0.9511 0
2 0 0 0
3 0 0 0
End values
Result "Displacement" "Wave" 7 Vector OnNodes
Values
1 1.4 0.809 0
2 0 0 0
3 0 0 0
End values
Result "Displacement" "Wave" 8 Vector OnNodes
Values
1 1.6 0.5878 0
2 0 0 0
3 0 0 0
End values
Result "Displacement" "Wave" 9 Vector OnNodes
Values
1 1.8 0.309 0
2 0 0 0
3 0 0 0
End values
Result "Displacement" "Wave" 10 Vector OnNodes
Values
1 2 1.225e-16 0
2 0 0 0
3 0 0 0
End values
