[GiDlist] Symmetric meshes
Hi! What is the way to create symmetric meshes?
Thanks in advance!
Gero.
Thanks in advance!
Gero.
[GiDlist] GID 7.1 on Windows NT 4.0
Dear All,
Sometimes, I am using GID on windows NT 4.0 : some problems appear,
especially,
it is no more possible to select, on a GID's geometry, several lines
together (or surfaces together)
using the mouse.
In fact, the selection of entities is only possible entity by entity.
Is it a known bug ?
Is there a solution (GID 7.2 of course, but an other one if possible !)
Thank you in advance.
G.W.R. Geis
especially,
using the mouse.
Is it a known bug ?
G.W.R. Geis
You can create a mirror of the mesh elements (utility copy).
Note: you must then apply the conditions and materials directly to the mesh.
To: "GIDLIST" gidlist at gatxan.cimne.upc.es
Sent: Wednesday, April 23, 2003 11:45 AM
Subject: [GiDlist] Symmetric meshes
Thanks in advance!
Gero.
Thanks in advance!
Gero.
This bug is unknown. In fact, GiD works ok on Win NT 4.0 in our tests.
In any case, if GiD 7.2 works in your system, what's the problem to update?
The password is the same
To: "GID" GiDlist at gatxan.cimne.upc.es
Sent: Wednesday, April 23, 2003 12:16 PM
Subject: [GiDlist] GID 7.1 on Windows NT 4.0
Dear All,
especially,
using the mouse.
Is it a known bug ?
G.W.R. Geis
Dear All,
especially,
using the mouse.
Is it a known bug ?
G.W.R. Geis
Thank you for your message.
I cannot explain why this bug is, but it is !
I ever installed a GID 7.1 version on a Windows NT 4.0 network, it was running,
but now, in an other WNT4.0 network, this bug appears !!
At the moment, I prefer to use the GID 7.1 version, because all my software is
developed from GID 7.1
Especially, the GID 7.2 version has a little problem with the automatic reading
of the *.flavia.msh (cf. Problem with *.flavia.msh in GID 7.2 - 21/03/03). I
should be necessary for me to change some lines specifically for the 7.2
version, and change again for the 7.3 version...
In fact I am waiting for the next version of GID...
G.W.R. Geis
Dear All,
especially,
using the mouse.
Is it a known bug ?
G.W.R. Geis
G.W.R. Geis
Dear All,
especially,
using the mouse.
Is it a known bug ?
G.W.R. Geis
Hello;
In Windows 2000 (pro) (kernell NT), and GID 7.2 has the same bug when select
several lines together.
Pablo
G.W.R. Geis
Dear All,
especially,
using the mouse.
Is it a known bug ?
G.W.R. Geis
Pablo
G.W.R. Geis
Dear All,
especially,
using the mouse.
Is it a known bug ?
G.W.R. Geis
I' develop under Windows 2000 professional, and this problem not appears in
any of our machines!!
For example (using GiD 7.1 or 7.2): It fail if you create some lines, and
try to list it selecting all ?
It is, can be, a redraw problem?
From: "Pablo Perez del Castillo" pablopdc at terra.es
Sent: Wednesday, April 23, 2003 6:21 PM
Subject: Re: [GiDlist] GID 7.1 on Windows NT 4.0
Hello;
select
Pablo
running,
software is
reading
21/03/03). I
G.W.R. Geis
update?
Dear All,
especially,
using the mouse.
entity.
Is it a known bug ?
G.W.R. Geis
Hello;
select
Pablo
running,
software is
reading
21/03/03). I
G.W.R. Geis
update?
Dear All,
especially,
using the mouse.
entity.
Is it a known bug ?
G.W.R. Geis
Hello Enrique; you are right.
It is not happening with Gid tools, but if i use my tool (it is a tcl to create
splines similar to NACA profiles) and then i try to select all to get nurbs, i
must do it one to one. I tried to redraw, but nothin change. I guess, we have to
repair our tcl code.
Pablo
Hello;
select
Pablo
running,
software is
reading
21/03/03). I
G.W.R. Geis
update?
Dear All,
especially,
using the mouse.
entity.
Is it a known bug ?
G.W.R. Geis
Pablo
Hello;
select
Pablo
running,
software is
reading
21/03/03). I
G.W.R. Geis
update?
Dear All,
especially,
using the mouse.
entity.
Is it a known bug ?
G.W.R. Geis
Can you send some model, with this type of nurblines, to check it?
Sent: Wednesday, April 23, 2003 7:54 PM
create
nurbs, i
have to
Pablo
in
and
Hello;
select
Pablo
was
running,
software is
automatic
reading
21/03/03). I
7.2
G.W.R. Geis
tests.
to
update?
Dear All,
appear,
especially,
lines
using the mouse.
entity.
Is it a known bug ?
possible
G.W.R. Geis
create
nurbs, i
have to
Pablo
in
and
Hello;
select
Pablo
was
running,
software is
automatic
reading
21/03/03). I
7.2
G.W.R. Geis
tests.
to
update?
Dear All,
appear,
especially,
lines
using the mouse.
entity.
Is it a known bug ?
possible
G.W.R. Geis
a IGES file is joined.
It has been made from a GID geometry saved as a IGES format file.
This file induces the bug on WNT4.0
Bye,
G.W.R.Geis
Translator GID - IGES S0000001
1H,,1H;,3HGID,75HC:/Documents and Settings/Administrateur/Mes documents/G0000001
Johann/test/cube.igs,,,32,,,,,,1,,,1,0,,0,0,,5HCIMNE,9,,; G0000002
128 1 1 D0000001
128 12 NURBSURF 1D0000002
128 13 1 D0000003
128 13 NURBSURF 2D0000004
128 26 1 D0000005
128 14 NURBSURF 3D0000006
128 40 1 D0000007
128 13 NURBSURF 4D0000008
128 53 1 D0000009
128 13 NURBSURF 5D0000010
128 66 1 D0000011
128 13 NURBSURF 6D0000012
128,4,4,3,3,0,0,1,0,0,0,0,0,0,0.414105,1,1,1,1,0,0,0,0,0.5,1,1, 1P0000001
1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,-0.234302, 1P0000002
1.064019,-0.03,-0.147367,1.064019,-0.03,-0.024367,1.064019, 1P0000003
-0.03,0.098633,1.064019,-0.03,0.175698,1.064019,-0.03,-0.234302, 1P0000004
0.970619,-0.03,-0.147367,0.970619,-0.03,-0.024367,0.970619, 1P0000005
-0.03,0.098633,0.970619,-0.03,0.175698,0.970619,-0.03,-0.234302, 1P0000006
0.830519,-0.03,-0.147367,0.830519,-0.03,-0.024367,0.830519, 1P0000007
-0.03,0.098633,0.830519,-0.03,0.175698,0.830519,-0.03,-0.234302, 1P0000008
0.690419,-0.03,-0.147367,0.690419,-0.03,-0.024367,0.690419, 1P0000009
-0.03,0.098633,0.690419,-0.03,0.175698,0.690419,-0.03,-0.234302, 1P0000010
0.597019,-0.03,-0.147367,0.597019,-0.03,-0.024367,0.597019, 1P0000011
-0.03,0.098633,0.597019,-0.03,0.175698,0.597019,-0.03,0,1,0,1; 1P0000012
128,4,4,3,3,0,0,1,0,0,0,0,0,0,0.414105,1,1,1,1,0,0,0,0,0.5,1,1, 3P0000013
1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,0.175698, 3P0000014
0.597019,-0.03,0.175698,0.597019,0.014634,0.175698,0.597018, 3P0000015
0.077784,0.175698,0.597019,0.140934,0.175698,0.597019,0.1805, 3P0000016
0.175698,0.690419,-0.03,0.175698,0.690419,0.014634,0.175698, 3P0000017
0.690418,0.077784,0.175698,0.690419,0.140934,0.175698,0.690419, 3P0000018
0.1805,0.175698,0.830518,-0.03,0.175698,0.830518,0.014634, 3P0000019
0.175698,0.830518,0.077784,0.175698,0.830518,0.140934,0.175698, 3P0000020
0.830518,0.1805,0.175698,0.970618,-0.03,0.175698,0.970618, 3P0000021
0.014634,0.175698,0.970618,0.077784,0.175698,0.970618,0.140934, 3P0000022
0.175698,0.970618,0.1805,0.175698,1.064019,-0.03,0.175698, 3P0000023
1.064019,0.014634,0.175698,1.064019,0.077784,0.175698,1.064019, 3P0000024
0.140934,0.175698,1.064019,0.1805,0,1,0,1; 3P0000025
128,4,4,3,3,0,0,1,0,0,0,0,0,0,0.414105,1,1,1,1,0,0,0,0,0.5,1,1, 5P0000026
1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,-0.234302, 5P0000027
1.064019,-0.03,-0.234302,1.064019,0.014634,-0.234302,1.064019, 5P0000028
0.077784,-0.234302,1.064019,0.140934,-0.234302,1.064019,0.1805, 5P0000029
-0.234302,0.970619,-0.03,-0.234302,0.970619,0.014634,-0.234302, 5P0000030
0.970619,0.077784,-0.234302,0.970619,0.140934,-0.234302, 5P0000031
0.970619,0.1805,-0.234302,0.830519,-0.03,-0.234302,0.830519, 5P0000032
0.014634,-0.234302,0.830519,0.077784,-0.234302,0.830519, 5P0000033
0.140934,-0.234302,0.830519,0.1805,-0.234302,0.690419,-0.03, 5P0000034
-0.234302,0.690419,0.014634,-0.234302,0.690419,0.077784, 5P0000035
-0.234302,0.690419,0.140934,-0.234302,0.690419,0.1805,-0.234302, 5P0000036
0.597019,-0.03,-0.234302,0.597019,0.014634,-0.234302,0.597019, 5P0000037
0.077784,-0.234302,0.597019,0.140934,-0.234302,0.597019,0.1805, 5P0000038
0,1,0,1; 5P0000039
128,4,4,3,3,0,0,1,0,0,0,0,0,0,0.414105,1,1,1,1,0,0,0,0,0.5,1,1, 7P0000040
1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,-0.234302, 7P0000041
1.064019,0.1805,-0.147367,1.064019,0.1805,-0.024367,1.064019, 7P0000042
0.1805,0.098633,1.064019,0.1805,0.175698,1.064019,0.1805, 7P0000043
-0.234302,0.970619,0.1805,-0.147367,0.970619,0.1805,-0.024367, 7P0000044
0.970619,0.1805,0.098633,0.970619,0.1805,0.175698,0.970619, 7P0000045
0.1805,-0.234302,0.830519,0.1805,-0.147367,0.830519,0.1805, 7P0000046
-0.024367,0.830519,0.1805,0.098633,0.830519,0.1805,0.175698, 7P0000047
0.830519,0.1805,-0.234302,0.690419,0.1805,-0.147367,0.690419, 7P0000048
0.1805,-0.024367,0.690419,0.1805,0.098633,0.690419,0.1805, 7P0000049
0.175698,0.690419,0.1805,-0.234302,0.597019,0.1805,-0.147367, 7P0000050
0.597019,0.1805,-0.024367,0.597019,0.1805,0.098633,0.597019, 7P0000051
0.1805,0.175698,0.597019,0.1805,0,1,0,1; 7P0000052
128,4,4,3,3,0,0,1,0,0,0,0,0,0,0.414105,1,1,1,1,0,0,0,0,0.5,1,1, 9P0000053
1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,-0.234302, 9P0000054
0.597019,-0.03,-0.234302,0.597019,0.014634,-0.234302,0.597018, 9P0000055
0.077784,-0.234302,0.597019,0.140934,-0.234302,0.597019,0.1805, 9P0000056
-0.152302,0.597019,-0.03,-0.152302,0.597019,0.014634,-0.152302, 9P0000057
0.597019,0.077784,-0.152302,0.597019,0.140934,-0.152302, 9P0000058
0.597019,0.1805,-0.029302,0.597019,-0.03,-0.029302,0.597019, 9P0000059
0.014634,-0.029302,0.597019,0.077784,-0.029302,0.597019, 9P0000060
0.140934,-0.029302,0.597019,0.1805,0.093698,0.597019,-0.03, 9P0000061
0.093698,0.597019,0.014634,0.093698,0.597019,0.077784,0.093698, 9P0000062
0.597019,0.140934,0.093698,0.597019,0.1805,0.175698,0.597019, 9P0000063
-0.03,0.175698,0.597019,0.014634,0.175698,0.597018,0.077784, 9P0000064
0.175698,0.597019,0.140934,0.175698,0.597019,0.1805,0,1,0,1; 9P0000065
128,4,4,3,3,0,0,1,0,0,0,0,0,0,0.414105,1,1,1,1,0,0,0,0,0.5,1,1, 11P0000066
1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,0.175698, 11P0000067
1.064019,-0.03,0.175698,1.064019,0.014634,0.175698,1.064019, 11P0000068
0.077784,0.175698,1.064019,0.140934,0.175698,1.064019,0.1805, 11P0000069
0.093698,1.064019,-0.03,0.093698,1.064019,0.014634,0.093698, 11P0000070
1.064019,0.077784,0.093698,1.064019,0.140934,0.093698,1.064019, 11P0000071
0.1805,-0.029302,1.064019,-0.03,-0.029302,1.064019,0.014634, 11P0000072
-0.029302,1.064019,0.077784,-0.029302,1.064019,0.140934, 11P0000073
-0.029302,1.064019,0.1805,-0.152302,1.064019,-0.03,-0.152302, 11P0000074
1.064019,0.014634,-0.152302,1.064019,0.077784,-0.152302, 11P0000075
1.064019,0.140934,-0.152302,1.064019,0.1805,-0.234302,1.064019, 11P0000076
-0.03,-0.234302,1.064019,0.014634,-0.234302,1.064019,0.077784, 11P0000077
-0.234302,1.064019,0.140934,-0.234302,1.064019,0.1805,0,1,0,1; 11P0000078
S0000001G0000002D0000012P0000078 T0000001
Bye,
G.W.R.Geis
128 1 1 D0000001
128 13 1 D0000003
128 26 1 D0000005
128 40 1 D0000007
128 53 1 D0000009
128 66 1 D0000011
0,1,0,1; 5P0000039
