Pablo Perez del Castillo,
Thanks.
I want to display a results in Gid which has the different nodes belong to the same number of element.It 's mean that a remesh or move element question.
Can I do it.
Advanced thanks
You can write in flavia.res displazaments over nodes in every iteration or step time :
Result "Displacements" "movement" 3 Vector OnNodes
in this sample, "3" is the iteration or step time. In the post-process you can see animate deform etc...
I hope help you.
In the post :. view results -- deformation
edodo
fea at eyou.com
2003-04-15
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030415/31324c5c/attachment.htm
[GiDlist] a question about postprocess
