[GiDlist] Hotkey to rotation and zoom
Posted: Sun Apr 13, 2003 1:04 pm
by Jonas Forssell
Hello, Many pre/postprocessors and CAD programs have a hotkey (usually CTRL) which together with the mouse allows rotation and zooming at any time during the creation process. In GID it seems I need to select the trackball every time I'd like to do this which in my mind makes it a bit more cumbersome. Is there any alternative way available in GID, similar to the hotkey? Thanks/Jonas Forssell, Gothenburg, Sweden
Gå före i kön och få din sajt värderad på nolltid med Yahoo! Express
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030413/b39e531b/attachment.htm
Posted: Sun Apr 13, 2003 4:38 pm
by Miguel A. de Riera Pasenau
there are some already defined bindings up line 571 in tclfile-opengl file
in the 'scripts' directory, which uses the second and third button of
the mouse to do a dynamic zoom and pan, respectively.
They can be activated by uncommenting the following variable
set GidPriv(havecontextualbutton) 1
in line 27 fo ConfigureProgram.tcl, in the scripts directory.
You can define your own bindings too, in the same tclfile-opengl file.
Posted: Mon Apr 14, 2003 10:11 am
You can create a "macro" (utilities-graphical-Macros...) to a fast access with a key to this functions:
for example, set this shorcuts:
"F3" to a macro named "pan" with this macro code: dynamicpan
"F4" to a macro named "zoom" with this macro code: zoom dynamic
"F5" to a macro name "rotate" with the code: rotate trackball
Sent: Sunday, April 13, 2003 2:03 PM
Subject: [GiDlist] Hotkey to rotation and zoom
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030414/21fdcca3/attachment.htm
Name: not available
Type: image/bmp
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030414/21fdcca3/attachment.bin
Posted: Mon Apr 14, 2003 4:50 pm
by Ramon Ribó
The recommended solution, as Enrique pointed out, is to use macros.
However
it is possible to modify line 29 in file:
GiD installation/scripts/ConfigureProgram.tcl
#set GidPriv(ChangeButtonMeaning) 1
into
It permmits to achieve interesting effects with the mouse central and
right buttons.
http://www.compassis.com http://www.compassis.com/
ramsan at compassis.com
[mailto:gidlist-admin at gatxan.cimne.upc.es] En nombre de Jonas Forssell
Enviado el: domingo, 13 de abril de 2003 14:03
Asunto: [GiDlist] Hotkey to rotation and zoom
http://se.docs.yahoo.com/info/express/help/index.html Express
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030414/5321e6b7/attachment.htm
Posted: Mon Apr 14, 2003 7:54 pm
by Jonas Forssell
Ramon_Ribó ramsan at compassis.com wrote: Hello, The recommended solution, as Enrique pointed out, is to use macros. Howeverit is possible to modify line 29 in file: GiD installation/scripts/ConfigureProgram.tcl from: ------------------------------------- #set GidPriv(ChangeButtonMeaning) 1------------------------------------------------- into --------------------------------------------------set GidPriv(ChangeButtonMeaning) 1--------------------------------------------------- It permmits to achieve interesting effects with the mouse central and right buttons. Regards,
De: gidlist-admin at gatxan.cimne.upc.es [mailto:gidlist-admin at gatxan.cimne.upc.es] En nombre de Jonas Forssell
Thank you for all the good replies.
Several things to try out here. Once again thanks!
/Jonas
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030414/ac455456/attachment.htm
