[GiDlist] Mesh points local number
Andrea Calaon
Post by Andrea Calaon »
I'm writing an interface for a BEM software and I need to
provide point (mesh) boundary conditions.
The input file needs the number of the element AND the local
node. Only one of the elements sharing that node.
es: "DISPLX1 234 3 0.0000000e001"
where the condition DISPLX1 applies to the node 3 of element
234 (which could be of any kind).
Is it possible to obtain this information in some way with a tcl
function?
I thought a loop on the element connectivity table checking the
presence of an absolute node number coming from the
condition.
Andrea Calaon
Ashurst Lodge, Ashurst
Southampton, Hampshire
SO40 7AA, UK
Fax office: +44 23 80 292 853
Mobile: +44 7766 488 225
E-mail: andrea at beasy.com
Post by Enrique Escolano »
You can get from tcl, the information of the list of nodes/elements and values
of a condition with info condition "cond_name" mesh, for example:
set infocnd [.central.s info conditions Displacement mesh]
You can also get the mesh elements and make a loop over the elements to set an array, for example SingleElem(inode)
whit a elem number (only the last is stored)
set elemtypes [lindex [.central.s info mesh] 0 end]
foreach etype $elemtypes {
set infoelems [.central.s info mesh elements $etype]
#get a list with elemsnum elemsconec(1) ... elemsconec(1) elemsmat
#must verify the type and nnode of the element type
if { $etype == Triangle } {
foreach {i n1 n2 n3 mat} $infoelems {
set SingleElem($n1) "$i 1" ;#overwrite a previous element number, store only the last
set SingleElem($n2) "$i 2"
set SingleElem($n3) "$i 3"
#Then write your desired format
set res ""
foreach i $infocnd {
set nnode [lindex $i 1]
set fieldvalue [lindex $i 4] ;#change 4 to the apropiate field incex
append res "DISPLX1 $SingleElem($nnode) $fieldvalue\n"
return res
Note: This code is untested, but it can works with small corrections
Sent: Tuesday, April 01, 2003 1:08 PM
Subject: [GiDlist] Mesh points local number
function?
condition.
Andrea Calaon
SO40 7AA, UK
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030401/5ce3602b/attachment.htm
