[GiDlist] A bug of intersection
edodo
Post by edodo »
Hi all
I have attached a batch file,You can infort it use GID.you can find that there is some trouble.
        edodo
        fea at eyou.com
          2003-02-20
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030220/ea863449/attachment.obj
Miguel A. de Riera Pasenau
This is what you wanted (look at 1.gif)?
Which version are you using?
Are you using the 7.2?
edodo wrote:
Hi all
¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡edodo
¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡fea at eyou.com
¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡2003-02-20
1.bch Type: unspecified type (application/octet-stream)
Encoding: base64
Type: image/gif
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030220/c1d7474f/attachment.gif
ieea
[GiDlist] Calculate without meshing ?
Post by ieea »
Dear All,
In my problem type, I do not use mesh.
In fact, I am working directly with NURBS generated with GID.
I wish run an executable file with the "Calculate" command of GID,
but each time, GID informs that "do not forget to generate a mesh".
Is it possible to avoid this message ?
Thank you for your response
G.W.R.Geis
Post by Enrique Escolano »
It exists a problem with the revolution surface:
the first boundary line is not located with precision over the generated
surface. (in render mode, this line and the surface are separated)
We will try to correct this imprecisión of the surface creation as rapidly
as possible.
To: "gidlist at gid.cimne.upc.es" gidlist at gatxan.cimne.upc.es
Sent: Thursday, February 20, 2003 8:29 AM
Subject: [GiDlist] A bug of intersection
Hi all
        edodo
        fea at eyou.com
          2003-02-20
Remove the "standard" Calculate menu and submenus,
and add your own Calculate menu invoking your procedure
(see help-Tcl-Tk extension-Managing menus)
To: "GID list" GIDlist at gatxan.cimne.upc.es
Sent: Thursday, February 20, 2003 11:01 AM
Subject: [GiDlist] Calculate without meshing ?
Dear All,
G.W.R.Geis
ieea
[GiDlist] Problems reading IGES files
Post by ieea »
Dear All (although this message be specially intended to GID's
programers...)
I noticed there is some problems when reading some IGES files.
Especially, some IDEAS's IGES files are not readable with GID !
Have you ever encountered this kind of problem ?
I join a sphere designed with IDEAS and recorded in IGES format.
This one is not readable with GID 7.1.
Thank you for your response.
G.W.R. Geis
S 1
,,22HI-DEAS Master Series 8,44H/home/asfauxd/IDEAS/RONSARD/sphere_ideas.G 1
igs,,27HI-DEAS 3D IGES Translator 8,32,38,6,308,15,3HAny,1.0D0,2,2HMM,1,G 2
0.0D0,15H20030220.095101,.01D0,10000000.0D0,,,11,0,15H20030220.095101,; G 3
128 1 0 0 0 0 0 000010001D 1
128 0 6 24 4 F1 1D 2
502 25 0 0 0 0 0 000010000D 3
502 0 0 1 1 0D 4
126 26 0 0 0 0 0 000010001D 5
126 0 6 6 2 E1 1D 6
504 32 0 0 0 0 0 000010001D 7
504 0 0 1 1 0D 8
126 33 0 0 0 0 0 000010500D 9
126 0 0 2 1 0D 10
126 35 0 0 0 0 0 000010500D 11
126 0 0 2 1 0D 12
508 37 0 0 0 0 0 000010001D 13
508 0 0 1 1 0D 14
510 38 0 0 0 0 0 000010001D 15
510 0 6 1 1 F1 1D 16
514 39 0 0 0 0 0 000010001D 17
514 0 0 1 1 0D 18
186 40 0 0 0 0 0 000000001D 19
186 0 0 1 0 0D 20
128,8,4,2,2,1,0,0,0,0,0.0D0,0.0D0,0.0D0,1.0D0,1.0D0,2.0D0,2.0D0, 1P 1
3.0D0,3.0D0,4.0D0,4.0D0,4.0D0,0.0D0,0.0D0,0.0D0,1.0D0,1.0D0, 1P 2
2.0D0,2.0D0,2.0D0,1.0D0,1.0D0,2.0D0,1.0D0,1.0D0,1.0D0,2.0D0, 1P 3
1.0D0,1.0D0,1.0D0,1.0D0,2.0D0,1.0D0,1.0D0,1.0D0,2.0D0,1.0D0, 1P 4
1.0D0,2.0D0,2.0D0,4.0D0,2.0D0,2.0D0,2.0D0,4.0D0,2.0D0,2.0D0, 1P 5
1.0D0,1.0D0,2.0D0,1.0D0,1.0D0,1.0D0,2.0D0,1.0D0,1.0D0,1.0D0, 1P 6
1.0D0,2.0D0,1.0D0,1.0D0,1.0D0,2.0D0,1.0D0,1.0D0,0.0D0,-100.0D0, 1P 7
0.0D0,0.0D0,-100.0D0,0.0D0,0.0D0,-100.0D0,0.0D0,0.0D0,-100.0D0, 1P 8
0.0D0,0.0D0,-100.0D0,0.0D0,0.0D0,-100.0D0,0.0D0,0.0D0,-100.0D0, 1P 9
0.0D0,0.0D0,-100.0D0,0.0D0,0.0D0,-100.0D0,0.0D0,100.0D0, 1P 10
-100.0D0,0.0D0,100.0D0,-100.0D0,-100.0D0,0.0D0,-100.0D0, 1P 11
-100.0D0,-100.0D0,-100.0D0,-100.0D0,-100.0D0,-100.0D0,0.0D0, 1P 12
-100.0D0,-100.0D0,100.0D0,0.0D0,-100.0D0,100.0D0,100.0D0, 1P 13
-100.0D0,100.0D0,100.0D0,-100.0D0,0.0D0,100.0D0,0.0D0,0.0D0, 1P 14
100.0D0,0.0D0,-100.0D0,0.0D0,0.0D0,-100.0D0,-100.0D0,0.0D0, 1P 15
-100.0D0,-100.0D0,0.0D0,0.0D0,-100.0D0,0.0D0,100.0D0,0.0D0, 1P 16
0.0D0,100.0D0,100.0D0,0.0D0,100.0D0,100.0D0,0.0D0,0.0D0,100.0D0, 1P 17
100.0D0,0.0D0,100.0D0,100.0D0,-100.0D0,0.0D0,100.0D0,-100.0D0, 1P 18
-100.0D0,100.0D0,-100.0D0,-100.0D0,100.0D0,0.0D0,-100.0D0, 1P 19
100.0D0,100.0D0,0.0D0,100.0D0,100.0D0,100.0D0,100.0D0,100.0D0, 1P 20
100.0D0,100.0D0,0.0D0,0.0D0,100.0D0,0.0D0,0.0D0,100.0D0,0.0D0, 1P 21
0.0D0,100.0D0,0.0D0,0.0D0,100.0D0,0.0D0,0.0D0,100.0D0,0.0D0, 1P 22
0.0D0,100.0D0,0.0D0,0.0D0,100.0D0,0.0D0,0.0D0,100.0D0,0.0D0, 1P 23
0.0D0,100.0D0,0.0D0,0.0D0,4.0D0,0.0D0,2.0D0; 1P 24
502,2,0.0D0,100.0D0,0.0D0,0.0D0,-100.0D0,0.0D0; 3P 25
126,4,2,1,0,0,0,0.0D0,0.0D0,0.0D0,.5D0,.5D0,1.0D0,1.0D0,1.0D0, 5P 26
1.0D0,.707106781186547D0,1.0D0,.707106781186547D0,1.0D0,0.0D0, 5P 27
100.0D0,0.0D0,100.0D0,100.0D0,0.0D0,100.0D0, 5P 28
-9.81307786677359D-15,0.0D0,100.0D0,-100.0D0,0.0D0, 5P 29
-2.53745236592799D-14,-100.0D0,0.0D0,0.0D0,1.0D0,0.0D0,0.0D0, 5P 30
1.0D0; 5P 31
504,1,5,3,1,3,2; 7P 32
126,1,1,0,0,1,0,0.0D0,0.0D0,1.0D0,1.0D0,1.0D0,1.0D0,4.0D0,0.0D0, 9P 33
0.0D0,4.0D0,2.0D0,0.0D0,0.0D0,1.0D0,0.0D0,0.0D0,0.0D0; 9P 34
126,1,1,0,0,1,0,0.0D0,0.0D0,1.0D0,1.0D0,1.0D0,1.0D0,0.0D0,2.0D0, 11P 35
0.0D0,0.0D0,0.0D0,0.0D0,0.0D0,1.0D0,0.0D0,0.0D0,0.0D0; 11P 36
508,2,0,7,1,0,1,1,9,0,7,1,1,1,1,11; 13P 37
510,1,1,1,13; 15P 38
514,1,15,1; 17P 39
186,17,1,0; 19P 40
S 1G 3D 20P 40 T 1
