[GiDlist] Data link between two different dialogboxes
Posted: Fri Jan 17, 2003 3:18 pm
Hello!
Could you please suggest a method to incorporate the following features in a GID project.
1a) Adding a new submenu (for ex. under GID's main menu "Data") and associate with it the general dailogbox interface features similar to the one currently available with the "Materials" submenu.
1b) Is it possible to easily have with this new submenu, a user-defined special fields similar in action to the a_field_name#MAT#(book_name) available for "Materials" submenu?
2)How to link between two different submenu dialog boxes for data updating of a field? To explain this with an example, an entry value for a field "propertyID" in a dialogbox is to be updated in another dialogbox using a field "property_list" keeping a list of "propertyID"s info. This operation is to an extent resembles data updating possible with the special field a_field_name#MAT#(book_name).
Thanking you for your suggestions.
With best wishes,
Ravish
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030117/b215e3d1/attachment.htm
With best wishes,
Ravish
