[GiDlist] combobox in tcl-file
Posted: Tue Jan 07, 2003 1:52 pm
by Andreas Friedberg
hi everybody,
I've created a tcl-file for a problemtype that allows me to generate geometric entities from a window called "Geometry" with the procedure "Geometry". I need to create a sort of combobox widget inside this window with three standard values between which the user has to choose. I tried to do that with the listbox widget as described in the standard tcl-documentation, but I couldn't manage to assign the currently selected value of the listbox to a global variable so as to use this information later on in the procedure "Draw". So I had to create three checkbuttons that can be turned on and off, but this solution is not satisfying, because I don't know how to deselect the other two buttons when one of the checkbuttons is selected.
This is how looks my tcl-file now:
proc Geometrie {} {
global GeometriePriv
set w .gid.geometrie
InitWindow $w "Geometrie" GeometryWindow
frame $w.title
label $w.title.belastungsArt -text " Belastungsart "
frame $w.check
label $w.check.sLt -text " schlaffe Last "
checkbutton $w.check.sLcb -variable GeometriePriv(sL)
label $w.check.sPt -text " starre Plate "
checkbutton $w.check.sPcb -variable GeometriePriv(sP)
label $w.check.ePt -text " elastische Platte "
checkbutton $w.check.ePcb -variable GeometriePriv(eP)
if { $GeometriePriv(sL) } { $w.check.sPcb deselect
$w.check.ePcb deselect }
if { $GeometriePriv(sP) } { $w.check.sLcb deselect
if { $GeometriePriv(eP) } { $w.check.sLcb deselect
$w.check.sPcb deselect }
These last if-commands do not work instantly. In fact, what I need is a combobox like the ones implemented in the configuration files with the command:
QUESTION: Belastung#CB#(one,two,three)
VALUE: one
Then I need to store the currently selected value in a variable so I can use it in another procedure.
Can anybody help?
thanks, Andreas
Andreas
http://www.berlin.de - meine stadt im netz.
Nur 1 x Anmelden für 600 Warenproben und Gutscheine wie z.B. edle Shampoos, Zigarretten, CD´s, Süßigkeiten, Parfüms, Tiernahrung und vieles vieles mehr Jetzt unverbindlich informieren: http://www.probenwelt.de/partner/?id=33
Posted: Wed Jan 08, 2003 12:08 pm
You can use a combobox Bwidget (the Bwitgets code is included by default to be used from GiD)
with -textvariable linked to your global variable, for example:
proc Geometrie {} {
set GeometriePriv(Belastungsart) "three"
frame $w.title
label $w.title.lb -text "Belastungsart"
combobox $w.title.combo -editable 0 -textvariable GeometriePriv(Belastungsart)
$w.title.combo add "one"
$w.title.combo add "two"
$w.title.combo add "three"
button $w.title.but -text "See Value" -command SeeValue
grid $w.title.lb $w.title.combo
grid $w.title.but
grid $w.title
proc SeeValue {} {
WarnWin $GeometriePriv(Belastungsart)
It is also possible, to separate the showed text from the variable value
(of interest for example in multilingual translations), using -command
to update the variable value from the combobox and with a variable value
trace to update the combobox text
From: "Andreas Friedberg" friedberg.andreas at berlin.de
Sent: Tuesday, January 07, 2003 1:50 PM
Subject: [GiDlist] combobox in tcl-file
hi everybody,
proc Geometrie {} {
frame $w.title
frame $w.check
VALUE: one
Can anybody help?
thanks, Andreas
Andreas
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030108/0483a3d0/attachment.htm
Posted: Wed Jan 08, 2003 8:33 pm
Sorry,a small bug, in the previous example, the combo widget works ok in GiD, but is not a BWidget (the BWidget does not have the "add" method).
To use the bwidget, instead
use:
ComboBox $w.title.combo -editable 0 -textvariable GeometriePriv(Belastungsart) -values {"one" "two" "three"}
Note the upper letters of the "ComboBox" Bwidget command and the -values parameter
Sent: Wednesday, January 08, 2003 12:13 PM
Subject: Re: [GiDlist] combobox in tcl-file
proc Geometrie {} {
frame $w.title
grid $w.title.but
grid $w.title
proc SeeValue {} {
hi everybody,
proc Geometrie {} {
frame $w.title
frame $w.check
VALUE: one
Can anybody help?
thanks, Andreas
Andreas
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030108/e0ba55b8/attachment.htm
[GiDlist] How to create a Table in tcl?
Posted: Thu Jan 09, 2003 8:57 am
by VSayako Willy
Hi GiD Team
How can we create a Table (somehow like Table in
word or excel) with the tcl/Tk? any one has some
ideas? Please advice.
Warm Regards
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
Posted: Thu Jan 09, 2003 10:42 am
See the Tktable widget from:
http://tktable.sourceforge.net/
Sent: Thursday, January 09, 2003 8:56 AM
Subject: [GiDlist] How to create a Table in tcl?
Hi GiD Team
Warm Regards
Do you Yahoo!?
[GiDlist] sharp angle in Tdyn3d
Posted: Fri Jan 10, 2003 11:25 am
by Pablo Perez del Castillo
Hello;
In Ransol demo, i am trying to modelate a wing with diferent section
along the span, so the sharp angle is changing along the span, Tdyn3d
has option about sharp angle to correct velocities in the trailing edge,
is it necesary to mark?, it is necesary what angle i must to entry,??
Advanced thanks
Pablo
Posted: Fri Jan 10, 2003 5:52 pm
Sharp_Angle should be slightly greater than the maximum angle of the
wing. This will apply the correct condition for the whole wing.
Sent: Friday, January 10, 2003 6:18 PM
Subject: [GiDlist] sharp angle in Tdyn3d
Hello;
Advanced thanks
Pablo
Posted: Fri Jan 10, 2003 6:45 pm
Hello again;
I try with and without Sharp_Angle the same wing, and it gets lift and drag
bigger than without S_A, so can you explain me how works this option inside
the solver, or what is the physical sense of this option? (it force the
trailing edge to kutta condition??)
A lot of thanks
Pablo
Hello;
Advanced thanks
Pablo
Posted: Fri Jan 10, 2003 7:17 pm
Sorry, I' unknown this concepts about the problem type Tdyn. I' only known
about GiD.
Try to send your Tdyn CFD questions to info at compassis.com
Sent: Saturday, January 11, 2003 1:38 AM
Subject: Re: [GiDlist] sharp angle in Tdyn3d
Hello again;
drag
inside
A lot of thanks
Pablo
Hello;
edge,
Advanced thanks
Pablo
