[GiDlist] RE: Problems with move point and arcline
Posted: Wed Sep 08, 2004 1:26 pm
But, if the arc define two surfaces and these surfaces define four volume,
I'd have to create all entities again.
Is there another option??
Damián
Subject: Re: [GiDlist] Problems with move point and arcline
Date: Tue, 7 Sep 2004 14:57:15 +0200
Reply-To: gidlist at gid.cimne.upc.es
Instead to "deform" the previous arc with "move point", you can simply
create a new arc and delete the old one.
From: "HRYB Damian Emmanuel CINI" SIDHRY at siderca.com
Sent: Monday, September 06, 2004 7:08 PM
Subject: [GiDlist] Problems with move point and arcline
Hi gid list,
I draw an arcline defined by 3 points, then I need to modify the arcline
shape and dimension using move point but I just have access to 2 arc
points.
If I move that 2 points I don't obtain the desired arc. What can I do?
Damián
Damián
Hi gid list,
points.
Damián
