Warning: This message has had one or more attachments removed.
Warning: Please read the "VirusWarning.txt" attachment(s) for more information.
Dear GiD Team
I have a problem when trying to run my project.gid files, a material
was set like:
BOOK: uniaxialMat
NUMBER: 11 MATERIAL: uniElastic
QUESTION:consider_uniElastic#CB#(0,1)
VALUE:0
QUESTION: uni_E:
VALUE:30000
QUESTION: uni_damping:
VALUE:0.0
END MATERIAL
and in the project.bas file, the material is called as:
*loop materials
*If(MatProp(consider_uniElastic,Int)!=0)*\
uniaxialMaterial Elastic *MatNum *MatProp(uni_E) *MatProp(uni_damping)
*endif
*End materials
when trying to write the calculation file, I am having the following error:
Error in base file C:\... at line number ...: word: 'uni_E' doesn't exist
In this case I am not selecting this particular material within the
problem am solving, so the *.bas file must actually pass over this
isntruction and do nothing, which is not the case.
Could you give me a hint on what might be the problem. I am attaching
the project files
Url: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040808/55ba4c5e/attachment.txt
Url: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040808/55ba4c5e/attachment-0001.txt
This is a message from the MailScanner E-Mail Virus Protection Service
The original e-mail attachment "EMOpenSEEs.mat"
is on the list of unacceptable attachments for this site and has been
replaced by this warning message.
If you wish to receive a copy of the original attachment, please
e-mail helpdesk and include the whole of this message
in your request. Alternatively, you can call them, with
the contents of this message to hand when you call.
At Sun Aug 8 20:25:53 2004 the virus scanner said:
Microsoft Access Shortcuts are dangerous in email in EMOpenSEEs.mat
Note to Help Desk: Look on the MailScanner in /var/spool/mailscanner/quarantine (message i78IPG8H003573).
Postmaster
Url: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040808/55ba4c5e/attachment-0002.txt
[GiDlist] .bas problem
Comments about your bas code:
*loop materials
*endif
*End materials
1 ) *\ seems incorrect at the end of a *if command
2) loop materials make a loop over all materials assigned to entities. In
order to use *If(MatProp(consider_uniElastic,Int)!=0) must
be sure that all defined materials have a field named "consider_uniElastic",
and in your case other materials don't have this field !!!
You can create a field (can be hidden) defined for all materials to identify
before use other fields, for example
QUESTION: TypeId
VALUE: elastic
STATE: Hidden
Are you are sure that the field "uni_E" is really defined for all loops ??
Note: Some of your attached files are removed by the mail server antivirus,
please for further messages send a zip file with single extension.
From: "Esneyder Montoya" esneyder.montoya at utoronto.ca
To: gidlist at GATXAN.CIMNE.UPC.ES
Sent: Sunday, August 08, 2004 8:08 PM
Subject: [GiDlist] .bas problem
information.
Dear GiD Team
was set like:
BOOK: uniaxialMat
VALUE:0
QUESTION: uni_E:
VALUE:30000
VALUE:0.0
END MATERIAL
*loop materials
*endif
*End materials
error:
the project files
# General purpose 3D-FEA #
# Using GID Pre-Processor For OpenSees #
# GID Problem type : EMOpenSEEs #
# Written by : Esneyder Montoya, Ph.D., P.Eng. #
# MontoyaE at mmm.ca #
# This file is a template for translating GID information #
# into OpenSees TCL input file #
# Date : July, 19, 2004 #
# Updated: July, 26, 2004 ##
# This file is created from GID pre- and post-processor #
# using "EMOpenSEEs.gid" Problem Type #
# Start of model generation
# Create ModelBuilder
*if(strcmp(GenData(Type_of_Problem),"Uniaxial")==0)
model BasicBuilder -ndm 1 -ndf 1
*elseif(strcmp(GenData(Type_of_Problem),"2D-Frame")==0)
model BasicBuilder -ndm 2 -ndf 3
*elseif(strcmp(GenData(Type_of_Problem),"PlaneStress2D")==0)
model BasicBuilder -ndm 2 -ndf 2
*elseif(strcmp(GenData(Type_of_Problem),"PlaneStrain2D")==0)
*elseif(strcmp(GenData(Type_of_Problem),"3D-Frame")==0)
model BasicBuilder -ndm 3 -ndf 6
*elseif(strcmp(GenData(Type_of_Problem),"Solids")==0)
*endif
# source files (library)
source RCcircSection.tcl
source MomentCurvature.tcl
source RCcircwallSection.tcl
source RCsection.tcl
source Units&Constants.tcl
# Create nodes & add to Domain - command: node nodeId ($coord)
*loop nodes
*format "%8i %10.3f %10.3f %10.3f"
node *NodesNum *NodesCoord(1) *NodesCoord(2) *NodesCoord(3)
*end nodes
# Create masses at nodes - command: mass nodeId (ndf $mass)
*Set Cond mass
*loop nodes *OnlyInCond
*format "%8i %10.1f %10.1f %10.1f %10.2f %10.2f %10.2f"
mass *NodesNum *cond(1) *cond(2) *cond(3) *cond(4) *cond(5) *cond(6)
*end nodes
# Nodal Constraints - command: fix nodeId (ndf $constr)
*Set Cond Point-Constraints
*format "%8i %8i %8i %8i %8i %8i %8i"
fix *NodesNum *cond(1) *cond(2) *cond(3) *cond(4) *cond(5) *cond(6)
*end nodes
# Multipoint Constraints
# 1) equalDOF - command: equalDOF $master $slave ($dof)
*Set Cond equalDOF
*if(strcmp(cond(1),"Master")==0)*\
*\equalDOF *NodesNum *\
*if(strcmp(cond(1),"Slave")==0)*\
*Format "%8i %8i %8i %8i %8i %8i %8i"
*\ *NodesNum *cond(2) *cond(3) *cond(4) *cond(5) *cond(6) *cond(7)
*endif
*end nodes
*endif
*end nodes
# 2) rigidDiaphragm - command: rigidDiaphragm $perpDirn $masternode
($slavenodes)
*Set Cond rigidDiaphragm *OnlyInCond
*if(strcmp(cond(1),"XY")==0)
rigidDiaphragm 3 *\
*elseif(strcmp(cond(1),"XZ")==0)
rigidDiaphragm 2 *\
*elseif(strcmp(cond(1),"YZ")==0)
rigidDiaphragm 1 *\
*endif
*if(strcmp(cond(2),"Master")==0)
*Nodesnum *\
*if(strcmp(cond(2),"Slave")==0)
*NodesNum *\
*endif
*end nodes
*endif
*end nodes
# 3) rigidLink- command: rigidLink $type(rod,beam) $master $slave
*Set Cond rigidLink *OnlyInCond
*if(strcmp(cond(1),"rod")==0)*\
rigidLink rod *\
*elseif(strcmp(cond(1),"beam")==0)*\
rigidLink beam *\
*endif
*NodesNum *\
*NodesNum
*endif
*end nodes
*endif
*end nodes
# Materials
# uniAxial Materials
# 1) Elastic -Command: uniaxialMaterial Elastic $tag $E $damping
*loop materials
*endif
*End materials
# 2) Elastic-Perfectly Plastic
*loop materials
*If(MatProp(consider_uniElasticPP,Int)!=0)*\
uniaxialMaterial ElasticPP *MatNum *MatProp(PP_E)
*MatProp(PP_epsyP)*MatProp(PP_epsyN) *MatProp(PP_epsyO)
*endif
*End materials
# 3) Elastic-Perfectly Plastic GAP tension
*loop materials
*If(MatProp(consider_tensionGAP,Int)!=0)*\
uniaxialMaterial ElasticPPGap *MatNum *MatProp(gap_E) *\
*MatProp(gap_Fy) *MatProp(initial_gap)
*endif
*End materials
# 4) Elastic-Perfectly Plastic GAP compression
*loop materials
*If(MatProp(consider_compGAP,Int)!=0)
uniaxialMaterial ElasticPPGap *MatNum *MatProp(gap_Ecomp) *\
*MatProp(gap_Fycomp) *MatProp(initial_gapcomp)
*endif
*End materials
# 5) Hardening
*loop materials
*If(MatProp(consider_HardeningMaterial,Int)!=0)
uniaxialMaterial Hardening *MatNum *MatProp(Hard_E) *\
*MatProp(Hard_Fy) *MatProp(Iso_Hard_Mod) *MatProp(Kin_Hard_Mod)
*MatProp(visco_plastic_coef)
*endif
*End materials
# 6) Elastic_NoTension
*loop materials
*If(MatProp(consider_Elastic_NoTension,Int)!=0)
uniaxialMaterial ENT *MatNum *MatProp(ENT_E)
*endif
*End materials
# 7) HystereticMat
*loop materials
*If(MatProp(consider_HystereticMat,Int)!=0)
uniaxialMaterial Hysteretic *MatNum *MatProp(HM_stress1p) *\
*MatProp(HM_stress1p) *MatProp(HM_strain1p) *MatProp(HM_stress2p)
*MatProp(HM_strain2p) *\
*MatProp(HM_stress3p) *MatProp(HM_strain3p) *\
*MatProp(HM_stress1n) *MatProp(HM_strain1n) *MatProp(HM_stress2n)
*MatProp(HM_strain2n) *\
*MatProp(HM_stress3n) *MatProp(HM_strain3n) *MatProp(HM_pinchstrain)
*MatProp(HM_pinchstrain)*\
*MatProp(HM_pinchstress) *MatProp(HM_ductdamage)
*MatProp(HM_energydamage) *MatProp(HM_degradedunlstiff)
*endif
*End materials
# 8) ViscousMat
*loop materials
*If(MatProp(consider_ViscousMat,Int)!=0)
uniaxialMaterial Viscous *MatNum *MatProp(VM_tangent)
*MatProp(VM_damping)
*endif
*End materials
# 9) STEEL
# 9a) Steel01
*loop materials
*If(MatProp(consider_Steel01,Int)!=0)
uniaxialMaterial Steel01 *MatNum *MatProp(Steel01_Fy)
*MatProp(Steel01_Eo) *\
*MatProp(Steel01_hard_ratio) *MatProp(Steel01_hard_ratio)
*MatProp(Steel01_a1) *\
*MatProp(Steel01_a2) *MatProp(Steel01_a3) *MatProp(Steel01_a4)
*endif
*End materials
# 9b) Steel02
*loop materials
*If(MatProp(consider_Steel02,Int)!=0)
uniaxialMaterial Steel02 *MatNum *MatProp(Steel02_Fy)
*MatProp(Steel02_Eo) *\
*MatProp(Steel02_hard_ratio) *MatProp(Steel02_R0) *MatProp(Steel02_cR1) *\
*MatProp(Steel02_cR2) *MatProp(Steel01_a1) *MatProp(Steel01_a2)
*MatProp(Steel01_a3) *\
*endif
*End materials
# 10) CONCRETE
# 10a) Concrete01 (compression curve)
*loop materials
*If(MatProp(consider_Concrete01,Int)!=0)
uniaxialMaterial Concrete01 *MatNum *MatProp(Concrete01_Fpc)
*MatProp(Concrete01_epsc0) *\
*MatProp(Concrete01_Fpcu) *MatProp(Concrete01_epscu)
*endif
*End materials
# 10b) Concrete02 (compression With linear tension softening)
*loop materials
*If(MatProp(consider_Concrete02,Int)!=0)
uniaxialMaterial Concrete02 *MatNum *MatProp(Concrete02_Fpc)
*MatProp(Concrete02_epsc0) *\
*MatProp(Concrete02_Fpcu) *MatProp(Concrete02_epscu)
*MatProp(Concrete02_lambda) *\
*MatProp(Concrete02_ft) *MatProp(Concrete02_Ets_linear)
*endif
*End materials
# 10c) Concrete03 (compression With nonlinear tension softening)
*loop materials
*If(MatProp(consider_Concrete03,Int)!=0)
uniaxialMaterial Concrete03 *MatNum *MatProp(Concrete03_Fpc)
*MatProp(Concrete03_epsc0) *\
*MatProp(Concrete03_Fpcu) *MatProp(Concrete03_epscu)
*MatProp(Concrete03_lambda) *\
*MatProp(Concrete03_ft) *MatProp(Concrete03_epsto)
*MatProp(Concrete03_fto) *\
*MatProp(Concrete03_beta) *MatProp(Concrete03_eptsu)
*endif
*End materials
# Frame Sections:
# 1) Elastic -command: Elastic $secTag $E $A $Iz $Iy $G $J
*loop materials
*If(MatProp(consider_elastic,Int)!=0)
section Elastic *MatNum *MatProp(Elastic_E) *\
*MatProp(Elastic_Area) *\
*MatProp(Elastic_Iz) *\
*MatProp(Elastic_Iy) *\
*MatProp(Elastic_G) *\
*MatProp(Elastic_J)
*endif
*End materials
# 2)proc RCsection {id h b cover coreID coverID steelID numBars
# barArea nfCoreY nfCoreZ nfCoverY nfCoverZ}
*loop materials
*If(MatProp(consider_Rect),Int)==1)
RCsection *\
*MatNum *MatProp(Rect_Height) *\
*MatProp(Rect_Width) *\
*MatProp(Rect_cover) *\
1 1 1 *\
*MatProp(Rect_NBarSide) *\
*MatProp(Rect_Ab) *\
15 15 15 1
*endif
*End materials
# 3)proc RCcircSection {id ri ro cover coreID coverID steelID
# numBars barArea nfCoreR nfCoreT nfCoverR nfCoverT}
*loop materials
*If(MatProp(consider_Circ),Int)==1)
RCcircSectio *\
*MatNum 0.0 *MatProp(Circ_radius) *\
*MatProp(Circ_cover) *\
1 1 1 *\
*MatProp(Circt_NBars) *\
*MatProp(Circ_Ab) *\
15 15 1 15
*endif
*End materials
# 4)proc RCcircwallSection {id ri ro cover coreID coverID steelID check!
*loop materials
*If(MatProp(consider_Circwall),Int)==1)
*MatNum *MatProp(Wall_ri) *\
*MatProp(Wall_ro)
*MatProp(Wall_cover) *\
1 1 1 *\
*MatProp(Wall_NBars) *\
*MatProp(Wall_Ab) *\
20 36 1 36
*endif
*End materials
# more materials here!
# Elements
*Set cond Truss
*loop elems *OnlyInCond
*If(cond(consider_TrussArea,Int)==1)
*Format "%5i %5i %5i %6.1f %4i"
element truss *elemsnum *ElemsConec *cond(TrussArea) *elemsmat
*Else
*Format "%5i %5i %5i %5i"
element truss *elemsnum *ElemsConec *elemsmat
*endif
*end elems
BOOK: GeneralConstraints
NUMBER: 1 CONDITION:Point-Constraints
CONDTYPE: over points
CONDMESHTYPE: over nodes
QUESTION:X#CB#(1,0)
VALUE:0
QUESTION:Y#CB#(1,0)
VALUE:0
QUESTION:Z#CB#(1,0)
VALUE:0
QUESTION:ROT-X#CB#(1,0)
VALUE:0
QUESTION:ROT-Y#CB#(1,0)
VALUE:0
QUESTION:ROT-Z#CB#(1,0)
VALUE:0
END CONDITION
NUMBER: 2 CONDITION:Line-Constraints
CONDTYPE: over lines
QUESTION:X-Constraint#CB#(1,0)
VALUE: 1
QUESTION:Y-Constraint#CB#(1,0)
VALUE: 1
QUESTION:Z-Constraint#CB#(1,0)
VALUE: 1
END CONDITION
NUMBER: 3 CONDITION: Point-Force-Load
QUESTION:X-Force
VALUE: 0.0
QUESTION:Y-Force
VALUE: 0.0
QUESTION:Z-Force
VALUE: 0.0
QUESTION:X-Moment
VALUE: 0.0
QUESTION:Y-Moment
VALUE: 0.0
QUESTION:Z-Moment
VALUE: 0.0
END CONDITION
NUMBER: 4 CONDITION:mass
QUESTION:X
VALUE:0.0
QUESTION:Y
VALUE: 0.0
QUESTION:Z
VALUE: 0.0
QUESTION:ROT-X
VALUE:0.0
QUESTION:ROT-Y
VALUE: 0.0
QUESTION:ROT-Z
VALUE: 0.0
END CONDITION
NUMBER: 5 CONDITION:rigidDiaphragm
QUESTION:Plane#CB#(none,XY,XZ,YZ)
VALUE:none
QUESTION:rigid#CB#(Master,Slave)
VALUE: Master
END CONDITION
NUMBER: 6 CONDITION: equalDOF
QUESTION: equalDOF:#CB#(Master,Slave)
VALUE: Master
QUESTION:X#CB#(1,0)
VALUE:1
QUESTION:Y#CB#(1,0)
VALUE: 1
QUESTION:Z#CB#(1,0)
VALUE: 0
VALUE:0
VALUE: 0
VALUE: 0
END CONDITION
NUMBER: 7 CONDITION:rigidLink
QUESTION:TypeLink#CB#(none,rod,beam)
VALUE:none
QUESTION:Link:#CB#(Master,Slave)
VALUE: Master
END CONDITION
NUMBER: 8 CONDITION: Line-Load
CONDMESHTYPE: over elems
QUESTION:Normal-Presure:
VALUE: 0.0
END CONDITION
BOOK: Frame Properties
NUMBER: 9 CONDITION: Truss
QUESTION:consider_TrussArea#CB#(1,0)
VALUE:0
QUESTION:TrussArea
VALUE:500
END CONDITION
NUMBER: 10 CONDITION: nonlinearBeamColumn
QUESTION:consider_NLBC#CB#(0,1)
VALUE:0
QUESTION:NLBC_numIntPoints:
VALUE:5
QUESTION:NLBC_mass(kg/m):
VALUE:100
QUESTION:NLBC_maxIter:
VALUE:1
QUESTION:NLBC_tol:
VALUE:10E-16
END CONDITION
NUMBER: 11 CONDITION: beamWithHinges
QUESTION:consider_bWH#CB#(0,1)
VALUE:0
QUESTION:bWH_HingeLi:
VALUE:500
QUESTION:bWH_HingeLj:
VALUE:500
QUESTION:bWH_mass(kg/m):
VALUE:100
QUESTION:bWH_maxIter:
VALUE:1
QUESTION:bWH_tol:
VALUE:10E-16
END CONDITION
NUMBER: 12 CONDITION: dispBeamColumn
QUESTION:consider_dBC#CB#(0,1)
VALUE:0
QUESTION:dBC_numIntPoints:
VALUE:5
QUESTION:dBC_mass(kg/m):
VALUE:100
END CONDITION
BOOK: FE Properties
NUMBER: 13 CONDITION: Quad
CONDTYPE: over surfaces
QUESTION:consider_Quad#CB#(0,1)
VALUE:0
QUESTION:Quad_thickness:
VALUE:250
QUESTION:Quad_pressure:
VALUE:0
QUESTION:Quad_density(kg/m3):
VALUE:2400
QUESTION:Quad_bodyforce1:
VALUE:0
QUESTION:Quad_bodyforce2:
VALUE:0
END CONDITION
NUMBER: 14 CONDITION: 8nodeBrick
CONDTYPE: over volumes
QUESTION:consider_8nodeBrick#CB#(0,1)
VALUE:0
QUESTION:8nodeBrick_density(kg/m3)
VALUE:2400
QUESTION:8nodeBrick_bodyforce1:
VALUE:0
QUESTION:8nodeBrick_bodyforce2:
VALUE:0
QUESTION:8nodeBrick_bodyforce3:
VALUE:0
END CONDITION
PROBLEM DATA
BOOK: ModelBuilder
QUESTION: Title
VALUE: Default_Title
QUESTION:
Type_of_Problem:#CB#(Uniaxial,2D-Frame,PlaneStress2D,PlaneStrain2D,3D-Frame,
Solids)
VALUE: 2D-Frame
BOOK: AnalysisGeneral
TITLE: Numberer
QUESTION: Numberer:#CB#(Plain,RCM)
VALUE: RCM
TITLE: Analysis
QUESTION: Analysis:#CB#(Static,Transient,VariableTransient)
VALUE: Static
TITLE: Eigen
QUESTION: Type_eigen#cb#(frequency,generalized,standard)
VALUE: standard
QUESTION: NumberEig
VALUE: 1
TITLE: Execution
QUESTION:
Solver:#CB#(BandSPD,BandGeneral,ProfileSPD,UmfPack,SparseSPD,SparseGeneral)
VALUE: BandSPD
QUESTION: LoadSteps
VALUE: 1
QUESTION: Increment
VALUE: 0.1
QUESTION: MinIncr
VALUE: 0.0
QUESTION: MaxIncr
VALUE: 0.0
QUESTION: NumberIterations
VALUE: 0
TITLE: ConvergenceTest
QUESTION: ConvergenceTest:#CB#(NormUnb,NormDispl,EnergyInc)
VALUE: NormUnb
QUESTION: Tolerance
VALUE: 0.0001
QUESTION: maxNumIter
VALUE: 40
QUESTION:
PrintOption#CB#(NoPrint,PrintEachStep,PrintwhenConverge,PrintNormdUdR,PrintE
rrorandContinueAnal)
VALUE: NoPrint
BOOK: AnalysisConstraints
TITLE: Plain
QUESTION: Plain#CB#(1,0)
VALUE: 1
TITLE: Lagrange
QUESTION: Lagrange#CB#(1,0)
VALUE: 0
QUESTION: LagSinglePointFactor
VALUE: 1
QUESTION: LagMultiplePointFactor
VALUE: 1
TITLE: Penalty
QUESTION: Penalty#CB#(1,0)
VALUE: 0
QUESTION: PenSinglePointFactor
VALUE: 100000
QUESTION: PenMultiplePointFactor
VALUE: 100000
TITLE: Transformation
QUESTION: Transformation#CB#(1,0)
VALUE: 0
BOOK: AnalysisAlgorithm
QUESTION: Linear#CB#(1,0)
VALUE: 1
QUESTION: Newton#CB#(1,0)
VALUE: 0
QUESTION: NewtonLineSearch#CB#(1,0)
VALUE: 0
QUESTION: ratio
VALUE: 0.5~0.8
QUESTION: ModNewton#CB#(1,0)
VALUE: 0
QUESTION: KrylovNewton#CB#(1,0)
VALUE: 0
QUESTION: BFGS#CB#(1,0)
VALUE: 0
QUESTION: Broyden#CB#(1,0)
VALUE: 0
QUESTION: numberIterWithinTimeStep
VALUE: 40
BOOK: AnalysisIntegrator
TITLE: LoadControl
QUESTION: LCFirstLoadInc#CB#(1,0)
VALUE: 1
VALUE: 1
QUESTION: LCFactorLoadInc
VALUE: 1
QUESTION: LCMinLoadInc
VALUE: 1
QUESTION: LCMaxLoadInc
VALUE: 1
TITLE: DisplControl
QUESTION: DisplControl#CB#(1,0)
VALUE: 0
QUESTION: ControlNode
VALUE: 0
QUESTION: DoF-X#CB#(1,0)
VALUE: 1
QUESTION: DoF-Y#CB#(1,0)
VALUE: 0
QUESTION: DoF-Z#CB#(1,0)
VALUE: 0
QUESTION: DoF-rotX#CB#(1,0)
VALUE: 0
QUESTION: DoF-rotY#CB#(1,0)
VALUE: 0
QUESTION: DoF-rotZ#CB#(1,0)
VALUE: 0
QUESTION: DCFirstDisplInc
VALUE: 1
QUESTION: DCFactorDisplInc
VALUE: 1
QUESTION: DCMinDisplInc
VALUE: 1
QUESTION: DCMaxDisplInc
VALUE: 1
TITLE: MinUnbDispl
QUESTION: MinUnbDispl#CB#(1,0)
VALUE: 0
QUESTION: MUDFirstLoadInc
VALUE: 1
QUESTION: MUDFactorLoadInc
VALUE: 1
QUESTION: MUDMinLoadInc
VALUE: 1
QUESTION: MUDMaxLoadInc
VALUE: 1
TITLE: ArcLength
QUESTION: ArcLength#CB#(1,0)
VALUE: 0
QUESTION: ArcLength
VALUE: 1
QUESTION: Alpha
VALUE: 30??
TITLE: Newmark
QUESTION: Newmark#CB#(1,0)
VALUE: 0
QUESTION: Newmgamma
VALUE: 0.5
QUESTION: Newmbeta
VALUE: 0.25
QUESTION: NewmalphaM
VALUE: 0.0
QUESTION: NewmbetaK
VALUE: 0.0
QUESTION: NewmbetaKinit
VALUE: 0.0
QUESTION: NewmbetaKcomm
VALUE: 0.0
TITLE: Hilbert-Hughes-Taylor
QUESTION: HHT#CB#(1,0)
VALUE: 0
QUESTION: HHTgamma
VALUE: 0.5
QUESTION: HHTalphaM
VALUE: 0.0
QUESTION: HHTbetaK
VALUE: 0.0
QUESTION: HHTbetaKinit
VALUE: 0.0
QUESTION: HHTbetaKcomm
VALUE: 0.0
END GENERAL DATA
*loop materials
*endif
*End materials
QUESTION: TypeId
VALUE: elastic
STATE: Hidden
information.
Dear GiD Team
was set like:
BOOK: uniaxialMat
VALUE:0
QUESTION: uni_E:
VALUE:30000
VALUE:0.0
END MATERIAL
*loop materials
*endif
*End materials
error:
the project files
*endif
*loop nodes
*end nodes
*Set Cond mass
*end nodes
*end nodes
*Set Cond equalDOF
*endif
*end nodes
*endif
*end nodes
($slavenodes)
rigidDiaphragm 3 *\
rigidDiaphragm 2 *\
rigidDiaphragm 1 *\
*endif
*Nodesnum *\
*NodesNum *\
*endif
*end nodes
*endif
*end nodes
rigidLink rod *\
rigidLink beam *\
*endif
*NodesNum *\
*NodesNum
*endif
*end nodes
*endif
*end nodes
# Materials
*loop materials
*endif
*End materials
*loop materials
*endif
*End materials
*loop materials
*endif
*End materials
*loop materials
*endif
*End materials
# 5) Hardening
*loop materials
*endif
*End materials
*loop materials
*endif
*End materials
# 7) HystereticMat
*loop materials
*endif
*End materials
# 8) ViscousMat
*loop materials
*endif
*End materials
# 9) STEEL
# 9a) Steel01
*loop materials
*endif
*End materials
# 9b) Steel02
*loop materials
*endif
*End materials
# 10) CONCRETE
*loop materials
*endif
*End materials
*loop materials
*endif
*End materials
*loop materials
*endif
*End materials
# Frame Sections:
*loop materials
*MatProp(Elastic_J)
*endif
*End materials
*loop materials
RCsection *\
1 1 1 *\
15 15 15 1
*endif
*End materials
*loop materials
RCcircSectio *\
1 1 1 *\
15 15 1 15
*endif
*End materials
*loop materials
*MatProp(Wall_ro)
1 1 1 *\
20 36 1 36
*endif
*End materials
# Elements
*Set cond Truss
*Else
*endif
*end elems
QUESTION:X#CB#(1,0)
VALUE:0
QUESTION:Y#CB#(1,0)
VALUE:0
QUESTION:Z#CB#(1,0)
VALUE:0
VALUE:0
VALUE:0
VALUE:0
END CONDITION
VALUE: 1
VALUE: 1
VALUE: 1
END CONDITION
QUESTION:X-Force
VALUE: 0.0
QUESTION:Y-Force
VALUE: 0.0
QUESTION:Z-Force
VALUE: 0.0
QUESTION:X-Moment
VALUE: 0.0
QUESTION:Y-Moment
VALUE: 0.0
QUESTION:Z-Moment
VALUE: 0.0
END CONDITION
QUESTION:X
VALUE:0.0
QUESTION:Y
VALUE: 0.0
QUESTION:Z
VALUE: 0.0
QUESTION:ROT-X
VALUE:0.0
QUESTION:ROT-Y
VALUE: 0.0
QUESTION:ROT-Z
VALUE: 0.0
END CONDITION
VALUE:none
VALUE: Master
END CONDITION
VALUE: Master
QUESTION:X#CB#(1,0)
VALUE:1
QUESTION:Y#CB#(1,0)
VALUE: 1
QUESTION:Z#CB#(1,0)
VALUE: 0
VALUE:0
VALUE: 0
VALUE: 0
END CONDITION
VALUE:none
VALUE: Master
END CONDITION
VALUE: 0.0
END CONDITION
VALUE:0
QUESTION:TrussArea
VALUE:500
END CONDITION
VALUE:0
VALUE:5
VALUE:100
VALUE:1
QUESTION:NLBC_tol:
VALUE:10E-16
END CONDITION
VALUE:0
VALUE:500
VALUE:500
VALUE:100
VALUE:1
QUESTION:bWH_tol:
VALUE:10E-16
END CONDITION
VALUE:0
VALUE:5
VALUE:100
END CONDITION
BOOK: FE Properties
VALUE:0
VALUE:250
VALUE:0
VALUE:2400
VALUE:0
VALUE:0
END CONDITION
VALUE:0
VALUE:2400
VALUE:0
VALUE:0
VALUE:0
END CONDITION
PROBLEM DATA
BOOK: ModelBuilder
QUESTION: Title
QUESTION:
Solids)
VALUE: 2D-Frame
TITLE: Numberer
VALUE: RCM
TITLE: Analysis
VALUE: Static
TITLE: Eigen
VALUE: standard
QUESTION: NumberEig
VALUE: 1
TITLE: Execution
QUESTION:
VALUE: BandSPD
QUESTION: LoadSteps
VALUE: 1
QUESTION: Increment
VALUE: 0.1
QUESTION: MinIncr
VALUE: 0.0
QUESTION: MaxIncr
VALUE: 0.0
VALUE: 0
VALUE: NormUnb
QUESTION: Tolerance
VALUE: 0.0001
VALUE: 40
QUESTION:
VALUE: NoPrint
TITLE: Plain
VALUE: 1
TITLE: Lagrange
VALUE: 0
VALUE: 1
VALUE: 1
TITLE: Penalty
VALUE: 0
VALUE: 100000
VALUE: 100000
VALUE: 0
VALUE: 1
VALUE: 0
VALUE: 0
QUESTION: ratio
VALUE: 0.5~0.8
VALUE: 0
VALUE: 0
VALUE: 0
VALUE: 0
VALUE: 40
TITLE: LoadControl
VALUE: 1
VALUE: 1
VALUE: 1
VALUE: 1
VALUE: 1
TITLE: DisplControl
VALUE: 0
VALUE: 0
VALUE: 1
VALUE: 0
VALUE: 0
VALUE: 0
VALUE: 0
VALUE: 0
VALUE: 1
VALUE: 1
VALUE: 1
VALUE: 1
TITLE: MinUnbDispl
VALUE: 0
VALUE: 1
VALUE: 1
VALUE: 1
VALUE: 1
TITLE: ArcLength
VALUE: 0
QUESTION: ArcLength
VALUE: 1
QUESTION: Alpha
VALUE: 30??
TITLE: Newmark
VALUE: 0
QUESTION: Newmgamma
VALUE: 0.5
QUESTION: Newmbeta
VALUE: 0.25
VALUE: 0.0
QUESTION: NewmbetaK
VALUE: 0.0
VALUE: 0.0
VALUE: 0.0
VALUE: 0
QUESTION: HHTgamma
VALUE: 0.5
QUESTION: HHTalphaM
VALUE: 0.0
QUESTION: HHTbetaK
VALUE: 0.0
VALUE: 0.0
VALUE: 0.0
END GENERAL DATA
