[GiDlist] new GiD 7.4.7b beta version
Posted: Tue May 04, 2004 12:57 pm
Hello GiD users.
A new GiD 7.4.7b beta version is available to download, by now only for Windows
( this week the Linux version will be ready)
It can be downloaded from: http://www.gidhome.com/download/do07.subst
This is a detailed (but not completely exhaustive) list of new features and corrected bugs (since version 7.4.6b, february):
New features:
- New smoother and quality measure, mesh quality check also by maximum edge.
- Saved auxiliary render file, to avoid recalculate it each time the model is openned.
- Optional variable GidPriv(CalculationFileExtension) to define the default extension for the calculation file of the problemtype
(it's also possible to set an extension from a .bas file located in /templates)
- New bas commands: *ElemsMatProp, *SetFormatNastran
- Undo window with commands grouped by colors, and optional compact visualization style
- New dev_kit tcl procedures:
GidUtils::PickEntities (now it can also select Dimensions and AllTypes)
GidUtils::SetCurrentLanguage (to set the language and it updates the menus, and windows)
GiD_FormatReal format realnum ?forcewidth|forcewidthnastran? (To get formatted real numbers)
GidUtils::CreateAdvanceBar, GidUtils::UpdateAdvanceBar, GidUtils::DeleteAdvanceBar (Functions to easily use an AdvanceBar)
- New tcl procedures to customize standard conditions, material, etc windows:
GiD_BookBehaviour, GiD_MaterialBehaviour and GiD_ConditionBehaviour
- Enhanced divide sets, including both sides if desired
- Postprocess import of binary Femap results file (.nfo) v1.0
Corrections:
- Don't close the current project when the action of openning a new project is cancelled
- Don't ask the user to delete old temporary files
- Corrections on sweep function
- Correct render smooth normals when user swap the normals
- Corrections transferring conditions over face elements
- Corrections of bad connectivities when generating structured hexahedrals linked with serial contact volumes
- Less memory required when generating structured meshes with lots of source geometric entities.
- Support layer names with spaces.
- New tcl GiD_Process command, to be used instead .central.s process (now using Tcl-like list style), and GiD_Info instead .central.s info
- Call to EndGidProject when user quits.
- Corrections on material and condition field dependencies
- #MAT# fields refreshed when adding or removing materials
- Corrected crash when listing many elements in postprocess
- Corrected and enhanced post cuts.
- Corrections on streamlines creation
- Corrections with gauss point results, and quadratic results (contour fill, smooth contour fill, etc)
_______________________________________________________
The GiD Team
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040504/2be28ba5/attachment.htm
New features:
Corrections:
The GiD Team
