In GiD the concept "geometry" is related to points, lines, surfaces, and volumes
the concep "mesh" is related to nodes and elements.
The *.bas file only manage mesh entities.
If do you want to export geometric entities, must use tcl commands (.central.s info). (Read help about Tcl-Tk extension)
As a trick, you can call a tcl procedure from the bas file with *tcl (the returned value is directly printed to the output file)
To:
Sent: Wednesday, March 17, 2004 12:16 PM
Subject: [GiDlist] Geometry data
Hello All,
Can GID export, through a *.bas file, the geometry data (nodes, faces and volumes)?
Thank you,
Cristina Costa
_____________________________________________________________________
Serviço de Webmail do Instituto Politécnico de Tomar ( IPT )
_______________________________________________ GiDlist mailing list
GiDlist at gid.cimne.upc.es http://gid.cimne.upc.es/mailman/listinfo/gidlist
URL:
http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040317/aaa74f3e/attachment.htm
