If you want to create geometry outside of GiD and import it in GiD,
you should
use one of the standard geometry interchange files that GiD supports,
These are
the following: DXF, IGES, PARASOLID, ACIS.
http://www.compassis.com http://www.compassis.com/
ramsan at compassis.com
De:
gidlist-admin at gatxan.cimne.upc.es
[mailto:
gidlist-admin at gatxan.cimne.upc.es] En nombre de Enrique Escolano
Enviado el: viernes, 30 de enero de 2004 11:01
Para:
Asunto: Re: [GiDlist] Preprocess Files
I attach a not oficial documentation, written in spanish, about the GiD
*.geo ASCII format.
dganit at hahotrim.com
To:
Sent: Thursday, January 29, 2004 9:22 PM
Subject: Re: [GiDlist] Preprocess Files
I want to create the geometry outside GiD.
What should be the format of the file to be able to do so ?
Dganit
escolano at cimne.upc.es Escolano
To:
Sent: Wednesday, January 28, 2004 1:29 PM
I don't understand your question.
If do you want to add a previous model to the current one, must use the
menu: Files-Import-Insert GiD Geometry...
To:
gidlist at gatxan.cimne.upc.es ;
dganit at evs.co.il
Sent: Tuesday, January 27, 2004 7:25 PM
Subject: [GiDlist] Preprocess Files
Hello everyone,
I want to open a pre-defined file in the preprocss, that already
contains the "shape" information.
Is it possible, and if it is how can I do it ?
Dganit
URL:
http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040130/1949d681/attachment.htm
