[GiDlist] menu items problem
Mark Smith
Post by Mark Smith »
GiD 7.5.8b OS win2000 SP4
Hi
I have a custom application which adds & removes menuitems via a .tcl file
e.g.
CreateMenu "Process" "PREPOST"
InsertMenuOption "Process" "Flight" 0 "run_1 { $dir }" "PREPOST"
RemoveMenuOption "Help" "Tutorials" "PREPOST"
RemoveMenuOption "Help" "What is new" "PREPOST"
etc...........
When I select this problem type, the menu bar customizes correctly but if I
use undo any time later after performing some actions I get GiD warnings
i.e. Menu ERROR:Option menu Tutorials doesn't exist in the preprocess , Menu
ERROR:Option menu What is new doesn't exist in the preprocess ...etc etc
depending on what menuoptions I have removed, it doesn't seem to stop the
undo but is an unwelcome feature :-(
As well as this I get a phantom extra menu item which is a copy of my
Process button without any sub options.
Is there any way to prevent this unwelcome behaviour? The custom application
worked perfectly on GiD 6.3.0b & win2000 ?
thanks in advance
regards
mark
the error.
