[GiDlist] RenumberMethod
Alexander Ahrens
Post by Alexander Ahrens »
is it possible to choose the renumbering Method in the current beta
version of GID for Linux ?
I'm working with gid7.5.8b-dyn.
Could you tell me how to set the variable RenumberMethod.
M.A. Ahrens
The GiD variables (like RenumberMethod) cannot be set from the standard
menus.
Can write in the lower command line (or using the right buttons, hidden by
default) this:
escape escape escape escape Utilities Variables RenumberMethod
And can set the values to
-1 --- disable node renumeration
0 --- default node renumbering (based on geometrical location)
1 --- Reverse Cuthill-Mckee based nodes renumeration
(The mesh is automatic renumbered after generate it)
From: "Alexander Ahrens" alexander.ahrens at rub.de
Sent: Tuesday, June 07, 2005 4:22 PM
Subject: [GiDlist] RenumberMethod
M.A. Ahrens
