[GiDlist] 7.5.3b in Linux
Hi Gid Team
I'm working with the 7.5.3b version on windows and this don't have any
problem, but I downloaded this version for Linux and I followed the steps of
the installation and didn't work, appers an error ('error de segmentación'
'segmentation fault'). So I installed other old version I don't have any
problem.
Kind Regards
Sebastián Callegari V.
problem.
Kind Regards
[GiDlist] Checking ..dat file
I wish create a function in my problem that allows the user to check the
..dat file before running the code. The input data would be also edited
in a only readable Tcl window. Obviously there is different ways (easy
or not) to obtain that result, but these from GID are often the easiest,
so...
Studying the NASTRAN problem type I noted the function entitled
WriteCalcFileCheck.
It seems that this function could be useful for my specific need. What
do think about it ? And, could you give more infos about this special
function ?
Thank you in advance.
G.W.R. Geis
so...
WriteCalcFileCheck.
function ?
G.W.R. Geis
Read GiD Help about Tcl-Tk exension-Event procedures
It exists a new GiD-Tcl event procedure for this pourpose (download last GiD
beta version to use this event), with this prototype:
proc BeforeWriteCalcFileGIDProject { file } {
...body...
set value ...
return $value
Your problemtye can define this procedure BeforeWriteCalcFileGIDProject ,
and it will automatically called by GiD before write the calculation file.
You must return "-cancel-" to abort to write the calculation file (if you
detect some bad parameter for example)
It also exists other similar procedure AfterWriteCalcFileGIDProject to be
called just after write the calculation file (then can show this file)
proc AfterWriteCalcFileGIDProject { file error } {
...body...
set value ...
return $value
About how to show the file, you can read the contents of the file in a
variable, named for example msg, and use our WarnWinText procedure to show
it.
Some like this:
set f [open $file r]
set msg [read $f]
close $f
WarnWinText $mgs
set value ""
return $value
To: "GIDliste" gidlist at gatxan.cimne.upc.es
Sent: Monday, March 14, 2005 10:33 AM
Subject: [GiDlist] Checking ..dat file
so...
WriteCalcFileCheck.
function ?
G.W.R. Geis
...body...
set value ...
return $value
...body...
set value ...
return $value
it.
Some like this:
set msg [read $f]
close $f
WarnWinText $mgs
set value ""
return $value
so...
WriteCalcFileCheck.
function ?
G.W.R. Geis
Could you send us which the Linux distribution where you are installing GiD
and if you are trying the dynamic or static release of GiD?
regards,
Jorge.
On Monday 14 March 2005 01:59, Sebastian Callegari Valenzuela wrote:
Hi Gid Team
of the installation and didn't work, appers an error ('error de
segmentación' 'segmentation fault'). So I installed other old version I
don't have any problem.
Kind Regards
regards,
Jorge.
Hi Gid Team
Kind Regards
[GiDlist] GID 7.5.5b BUG : materials and conditions name don
Please note that in GID 7.5.5b version, the names of assigned materials
don't appear on screen in some cases (!) whenever the "Draw -- colors"
function is called.
G.W.R. Geis
function is called.
G.W.R. Geis
Yes, this is a know bug.
In few days we expect to provide a new beta 7.5.6b including this
correction.
Thanks for your report.
Sent: Tuesday, March 15, 2005 11:23 AM
Subject: [GiDlist] GID 7.5.5b BUG : materials and conditions name don't
appear
function is called.
G.W.R. Geis
correction.
appear
function is called.
G.W.R. Geis
Thank you Enrique for your response,
The event procedures you send are OK in my case.
Could you, furthermore, give me a simple command to destroy directly the error
window (message : error running process) at the end of the
BeforeWriteCalcFileGIDProject procedure.
Thank you again,
G.W.R. Geis
...body...
set value ...
return $value
...body...
set value ...
return $value
it.
Some like this:
set msg [read $f]
close $f
WarnWinText $mgs
set value ""
return $value
so...
WriteCalcFileCheck.
function ?
G.W.R. Geis
Thank you again,
G.W.R. Geis
...body...
set value ...
return $value
...body...
set value ...
return $value
it.
Some like this:
set msg [read $f]
close $f
WarnWinText $mgs
set value ""
return $value
so...
WriteCalcFileCheck.
function ?
G.W.R. Geis
I don't know what's the cause of the related "error running process" message.
Maybe is because my sample has a bug: instead WarnWinText $msg I wrote WarnWinText $mgs
Or maybe you don't have a bat file to be run.
Note: WarnWinText not stop the execution flow (is non modal), you can create your own window for your pourposes, modal if necessary.
Sent: Tuesday, March 15, 2005 1:07 PM
Subject: Re: [GiDlist] Checking ..dat file
Thank you again,
G.W.R. Geis
...body...
set value ...
return $value
...body...
set value ...
return $value
it.
Some like this:
set msg [read $f]
close $f
WarnWinText $mgs
set value ""
return $value
so...
WriteCalcFileCheck.
function ?
G.W.R. Geis
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050315/549e1ebc/attachment.htm
Thank you again,
G.W.R. Geis
...body...
set value ...
return $value
...body...
set value ...
return $value
it.
Some like this:
set msg [read $f]
close $f
WarnWinText $mgs
set value ""
return $value
so...
WriteCalcFileCheck.
function ?
G.W.R. Geis
Sorry, my message is not really clear :
To check the ..dat file before running, I use the procedure (with the
corrected variable name $msg) you wrote for the
AfterWriteCalcFileGIDProject event procedure and that is OK. Doing that
I am sure that the ..dat file is really good before be ran.
Because I don't want that the ..bat file be executed just after, I
return -cancel- at the end of AfterWriteCalcFileGIDProject. Then the
error message "error running process" appears in a tk_dialogRAM window !
Now, I would like automatically destroy that error window in a event
procedure (BeforeRunCalculation or AfterRunCalculation ?). In a
consquence it will just appears the ..dat file written in the
WarnWinText.
But now, I cannot find the name of the tk_dialogRAM error window to
destroy it.
If you have got a solution to do that, I would be (obviously)
interested.
G.W.R. Geis
P.S. Maybe it is not easy to do. If not, there is no problem because at
the moment I can check my data file thanks to your procedure. My need is
only for comprehensive and friendly users of an user friendly interface
message. Maybe is because my sample has a bug: instead WarnWinText
$msg I wrote WarnWinText $mgsOr maybe you don't have a bat file to be
run. Note: WarnWinText not stop the execution flow (is non modal), you
Regards Enrique ----- Original Message -----From: "IEEA"
ieea at club-internet.frTo: gidlist at gatxan.cimne.upc.eduSent:
Tuesday, March 15, 2005 1:07 PMSubject: Re: [GiDlist] Checking ..dat
file Thank you Enrique for your response,
the error
Thank you again,
G.W.R. Geis
(download last GiD
...body...
set value ...
return $value
calculation file.
(if you
file)
....body...
set value ...
return $value
in a
to show
it.
Some like this:
set msg [read $f]
close $f
WarnWinText $mgs
set value ""
return $value
check the
edited
(easy
easiest,
so...
WriteCalcFileCheck.
need. What
special
function ?
G.W.R. Geis
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050317/8739c768/attachment.htm
WarnWinText.
destroy it.
interested.
G.W.R. Geis
the error
Thank you again,
G.W.R. Geis
(download last GiD
...body...
set value ...
return $value
calculation file.
(if you
file)
....body...
set value ...
return $value
in a
to show
it.
Some like this:
set msg [read $f]
close $f
WarnWinText $mgs
set value ""
return $value
check the
edited
(easy
easiest,
so...
WriteCalcFileCheck.
need. What
special
function ?
G.W.R. Geis
