Hello GiD Users.
There is a new GiD 7.5.5b beta version available for Windows (http://www.gidhome.com/download/do07.subst)
News of this beta version 7.5.5b
a.. Customizable macros toolbar
b.. Selection, add syntax "end-nº", for example: end , end-5:end
c.. Selection window: filters MinEdge and MaxEdge
d.. Selection of elements by tangency: ConnectedTangent and selected tolerance TolAngle (degrees)
e.. Selection: now it's possible to select element faces (to apply conditions)
f.. Sweep: must specify a end scale factor
g.. New GiD-Tcl commands:
a.. Added OpenGL selection commands: rendermode, selectbuffer, getselection
b.. GiD_GetInfoGeoFile, tr read the geo file version and problemtype
c.. GiD_Info Geometry
d.. Events: BeforeRunCalculation, AfterRunCalculation, AfterOpenFile , ChangedLanguage
h.. Creation of NURBS lines fitting a list of points instead interpolating, with user selected degree.
i.. Direct assignation to mesh of conditions with local axes
j.. Transformation (copy / move) much faster
k.. Function (meshing connectpoints) to create triangle elements (or surfaces) from a cloud of nodes, projecting in the plane z=0
l.. Several translation modifications: optionbar widget changed to Bwidget NoteBook, etc., language dependent widgets size
m.. Mesh quality: support for line and prism elements, new Minimum Jacobian criteria.
n.. Variable SymmetricalStructuredTriangles to create four triangles by quadrilateral instead two.
o.. Creation of approximated parametric surfaces
p.. Update to Tcl/Tk 8.4.9, and reordered and added some packages: tdom, img, treectrl
q.. Source code updated for 64 bits support.
r.. Split of prisms and hexahedras to tetrahedras
s.. Semi-structured meshes
t.. Check of negative of zero jacobian on elements
u.. Rjump enhancements: mesh of quadrilaterals, draw by colors of entities to be jumped, show advance bar, some new variables for better control: RJump(TakeCareCurvature), RJump(TakeCareLayers), RJump(TangencyLimitAngle)
v.. Transfer of applied conditions when splitting elements
w.. Mesh of structured tetrahedras.
x.. Structured hexahedras: corrected some degenerated cases, and enhanced interpolation of quadratic nodes.
y.. Problemtype xml file to declare some properties: to show a customized icon in the open file dialog box, to call a function to know if the entered password is valid for the problemtype, etc.
z.. Multiple mesh support (read, cuts, animations,etc.)
_______________________________________________________
http://www.gidhome.com escolano at cimne.upc.edu
CIMNE - Centro Internacional de Métodos Numéricos en Ingeniería
C/ Gran Capitán s/n, Modulo C1, Campus Norte UPC,
E-08034 Barcelona, Spain tel. +34 93 401 74 03
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050304/c64878e8/attachment.htm
[GiDlist] new GiD 7.5.5b beta version available for Windows
