[GiDlist] Pick button in bondary condition box
Jose Carlos
Post by Jose Carlos »
Dear GID Team,
I am developing a problem type to work with thermal-mechanics problems.
In my models, I need a boundary condition that uses some point's coordinates: x, y and z. So, my problem is:
I need put a "pick" button in a boundary condition window in GID. When I'll click in this button, it give me the coordinates x, y and z of the point clicked, just like occurs in the "copy" and "move" GID's windows.
Is it possible? I need information about the CND and BAS files to make it.
If it is possible only using TCL, how do I do it?
Thanks a lot for the attention.
José Carlos.
José Carlos Lopes Ribeiro, M. Sc.
Doctor in Structural Engineering
Civil Engineering
Federal University of Minas Gerais
BH - MG - Brazil
__________________________________________________________________________
Acabe com aquelas janelinhas que pulam na sua tela.
AntiPop-up UOL - É grátis!
http://antipopup.uol.com.br/
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050204/f36c11cc/attachment.htm
It not exists in our *.cnd file a "coordinates" field (to show a pick point button)
Maybe for future versions can add this feature as standard.
At this moment only is possible using Tcl/Tk. They are two options:
a) - Completly write your own alternative "conditions window" (can see the Tdyn problemtype as a sample)
b) - Change the central part of our window: read this paper, about "Tkwidget" of the last GiD Conference: http://www.gidhome.com/2004/papers/p236.pdf (can se the Ramseries problemtype as a sample)
can also use this two Tcl procedures (defined inside scripts/dev_kit.tcl)
proc GidUtils::GetCoordinates { { WarnLineMsg "" } { JoinNoJoin "Join" } }
# returns the coordinates x y z Or null selecting from the screen
# GidPriv(selcoord,id) store the point id (-1 nothing selected, 0 new point, 0 point id)
# to get the number of a existent point, cal also use PickEntities
# JoinNoJoin can be "Join" or "NoJoin"
proc GidUtils::PickEntities { type selectmode }
# type can be "Points" "Lines" "Surfaces" "Volumes" "Dimensions" "AllTypes" "Nodes" or "Elements"
# selectmode can be "single" or "multiple"
# for AllTypes selection returns some as
# Points 19 23 Lines 28:29 32:33 37 Surfaces 1 6 21:22 Volumes 1 Dimension 1:2
# or for mesh entities some as Nodes 236 244 Elements 4122 4130 4152 4165
In othe hand, I recommend to use 3 separated *cnd standard fields for x, y, z values,
and expect this new feature appear in next beta versions.
To: gidlist
Sent: Friday, February 04, 2005 12:53 AM
Subject: [GiDlist] Pick button in bondary condition box
Dear GID Team,
José Carlos.
Civil Engineering
BH - MG - Brazil
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050204/17420e6d/attachment.htm
