[GiDlist] view file format
Posted: Wed Feb 02, 2005 10:54 pm
Hello Marc.
It seems that already exists problems with this GiDList.
In my own case, can only reply to gidlist at gatxan.cimne.upc.es , but not to other alias as gidlist at gid.cimne.upc.edu !!
This view file is undocummented. In general it is not interesting for users.
(now maybe ti is interesting if somebody use OpenGL commands from Tcl)
The most important values are:
Clip planes:
{x -4.3476266860961914 7.0359973907470703} Left Right
{y 2.9231967926025391 -5.8392047882080078} Top Bottom
{z -17.291633605957031 17.291633605957031} Near Far
{e 5.7638778686523437}
{v 0.22276995494391905 -0.93294641779423648 0.26809183778641532}
{r -0.090062729314007287}
Transformation matrix 4x4:
{m -0.88452452421188354 -0.36737468838691711 0.2874930202960968 0.0
-0.46395501494407654 0.7570006251335144 -0.46010410785675049 0.0
-0.048601787537336349 -0.54035717248916626 -0.8400309681892395 0.0 0.0
0.0 0.0 1.0}
rotation center:
{c 0.0 0.0 0.0}
{pd -6.2774385622041925e+066}
{pno -6.2774385622041925e+066}
{pfo -6.2774385622041925e+066}
{pf 4.0}
{pv 0.0}
Note , it also exists an undocummented GiD-Tcl info command to obtain the current values: GiD_Info View
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050202/523ff906/attachment.htm
[GiDlist] tcl-error
Posted: Thu Feb 03, 2005 11:24 am
by Georg Haasemann
using the help of the new GiD v.7.5.3b for Linux, I get the following tcl-error:
unknown command "refresh" -- should be one of: cget clear configure href index insert names parse resolve selection text token xview yview debug
while executing
"$html($w) refresh"
(procedure "LoadFile" line 59)
invoked from within
"LoadFile $w $file 1 $tag"
(procedure "GiDHelpViewer::Select" line 50)
invoked from within
"GiDHelpViewer::Select .helpref 1 [Tree::_get_node_name .helpref.pw.f0.frame.nb.ftree.lf.tree current 2]"
(command bound to event)
What can I do?
Georg
PS: I'm using SUSE 9.1., TCL 8.4.6-26
[GiDlist] tcl-error
Posted: Thu Feb 03, 2005 7:24 pm
by Miguel A. Pasenau de Riera
Thanks, my mistake, i used an older version of the html lib. Now it is
corrected. You can download it again, from the same place.
De: gidlist-admin at gatxan.cimne.upc.edu.gid.cimne.upc.edu
[mailto:gidlist-admin at gatxan.cimne.upc.edu.gid.cimne.upc.edu] En nombre de
Georg Haasemann
Enviado el: jueves, 03 de febrero de 2005 11:03
Para: GID-Liste
Asunto: {SPAM?} [GiDlist] tcl-error
tcl-error:
while executing
"$html($w) refresh"
invoked from within
invoked from within
What can I do?
Georg
GiDlist at gid.cimne.upc.edu
