¿can you send us an example of both points?
thanks
_____
[mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de
vijayendra.munikoti at power.alstom.com
Enviado el: miércoles, 03 de mayo de 2006 15:10
Asunto: [GiDlist] GiD 8.0Rc
Hallo,
I have downloaded GiD 8.0Rc and evaluating. I have the following problems:
1) I am not able to export the GiD drawing to IGES/DXF or any other format.
The program exits with an error message.
2) After pre-processing the data and running FEM program, pressing the
post-processing button works to visualize the data. But after
post-processing if I press the pre-processing button, GiD exits with an
error message.
Could you help?
With regards
Vijayendra
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060503/f483a6d7/attachment.htm
[GiDlist] GiD 8.0Rc
[GiDlist] GiD 8.0Rc
Hallo
Thanks for the mail. Concerning the two points I had posted:
1) You can take ANY GiD generated drawing and export it as IGES/DXF. The
GiD gets terminated with an error message:
"The command "0x0068f8fa" referrs to memory "0x00000038". The
command "read" could not be executed"
2) You can open any GiD project and press post.-processing button. It
reads "..post.res" data. If you visualize/animate the data,
and THEN press pre-processing button, the "post-processing" menu does
not change at all.
Further, in post-processing menu, AFTER visualization, if you want to
change, for example number of contour colors or any other menu, nothing
happens, you have to literally close Gid and restart to set any menu item.
I have used previous GiD versions, so I think, that in this version there
is some bug.
Vijayendra
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060503/102ca14e/attachment.htm
not change at all.
is some bug.
Vijayendra
[GiDlist] Crack Problem
Hi
Can we use GiD for the crack problem???
New Yahoo! Messenger with Voice. Call regular phones from your PC and save big.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060504/801b6902/attachment.htm
What are your required features for "the crack problem"?
Maybe some tasks can be solved by an analysis code, and others must be implemented inside GiD.
Sent: Thursday, May 04, 2006 6:08 AM
Subject: [GiDlist] Crack Problem
Hi
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060505/22de7356/attachment.htm
Hi
