1) When I am spliting the elements (triangle-triangle, GiD8RC) I notice that the conditions are
either lost or transferred elsewere. (see pictures attached)
2) I would also like to ask if it is possible to split elements based on a background mesh.
Thanasis
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060419/e2482be6/attachment.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060419/e2482be6/attachment.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060419/e2482be6/attachment-0001.obj
[GiDlist] splitting_elements
Dear Sir,
We corrected this bug when splitting triangles with conditions over face element.
This second Release Candidate (available now for download) include several corrections like this.
About the other question, now It's not possible to split elements based on a background mesh, but you can use the standar selection mechanism, using some filter to select only some triangles (big triangles, or bad shaped, etc). Maybe we can add this feature for future versions.
Thanks for your bug report
Sent: Wednesday, April 19, 2006 8:05 PM
Subject: [GiDlist] splitting_elements
Thanasis
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060425/f082bbac/attachment.htm
Thanasis
