I use to run GiD in batch mode, trough command line. With Gid 7.2 I'm
successful launching problems such as "c:\gid directorygid.exe -b
batchfile.bat -n problem.gid".
Now I try to use the new beta version 7.7.6b and GiD crashes, giving the
typical windows message of "GiD has detected a problem and should be
closed".
I even try launching GiD alone ("c:\gid directorygid.exe"), and it
also crashes.
Any idea of what could be the problem?
My OS is windows XP.
Thanks in advance for your help.
Jose
[GiDlist] GiD crashes in batch mode
Hi Jose,
If I try to launch GiD 7.7.6b alone, it works well, and also with a simple
batch file
How do you launch it? from a DOS console?, from other code?
Can you start GiD 7.7.6 from the direct access icon? Can you then read this
batch?
Try to remove the -n flag
I don't have any idea about this problem, maybe must change before to the
GiD directory,
or there is some problem with spaces in the names.
Today we will made available for download the 7.7.7b beta, maybe this
problem doesn't appear with this version.
Sent: Tuesday, March 07, 2006 8:02 PM
Subject: [GiDlist] GiD crashes in batch mode
closed".
also crashes.
Jose
batch file
batch?
GiD directory,
closed".
also crashes.
Jose
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060308/1e888abb/attachment.htm
[GiDlist] new GiD beta for Linux
Hi GiD developers,
could you please provide the lastest GiD beta release for the linux/unix
platform?
Thanks a lot.
Martin
_/ _/_/ _/_/_/ Friedrich Alexander Universität Erlangen
_/ _/_/ _/_/
_/ _/ _/ _/ Department of Sensor Technology
_/_/_/ _/_/ _/_/_/ Paul-Gordanstr. 5, 91052 Erlangen, Germany
Dipl.-Ing. Martin Meiler
tel.: (+49)-9131-85-23140
fax.: (+49)-9131-85-23133
platform?
Thanks a lot.
Martin
_/ _/_/ _/_/
