Respected Sir
I am working on modeling of Tsunami waves using FEM , for this I have
done processing in Mat Lab and now i have results for each time
interval.
I want to plot this result in GID , some kind of Animation or some
thing
, currently i am able to view my result by making *.post.res file at
different time interval, but i am not able to do animation.
Can you please tell me , for doing animation type of thing in which
format i have to save my result , so that when i run my GID , it take
result from each time step in sequence.
Thanking you
DEVVRATH KHATRI
NA02B006
Final year B. Tech
IIT Madras
Chennai
India
[GiDlist] Animation using GID
Hello Mr. Khatri,
¿do you have a different mesh for each time step? ¿Something like
'time1.post.msh & time1.post.res', 'time2.post.msh & time2.post.res', ...,
'timeN.post.msh & timeN.post.res'? Then you can load them all at once by
selecting File-Open multiple in the top menu bar, and then, at the file
dialog, by selecting all the files at the same time: with click, shift-click
or control-click. Then you can animate the geometry or a contour fill or any
other result visualization.
If you have, instead, only one mesh, then it is not necessary to save each
time step in separate *.post.res files. You can save all the results in the
same file and just actualise the step value in the result headers.
Look at the 'result block' entry in the manual page
http://www.gidhome.com/support/gidbeta/gid_17.subst#SEC279
Hope it helps,
[mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de devvrath khatri
Enviado el: sábado, 04 de febrero de 2006 9:39
Asunto: [GiDlist] Animation using GID
Respected Sir
interval.
thing
Thanking you
DEVVRATH KHATRI
NA02B006
Final year B. Tech
IIT Madras
Chennai
India
Hope it helps,
Respected Sir
interval.
thing
Thanking you
DEVVRATH KHATRI
NA02B006
Final year B. Tech
IIT Madras
Chennai
India
