[GiDlist] how to create a surface on a sphere
Posted: Mon Nov 25, 2013 11:12 am
Thank you for your reply.
Actually, what I would like to do is to make a volume
which is obtained by cutting a pyramid with a sphere centered at a vertex
of the pyramid.
So the five sides of the volume are on planes but one is a spherical
surface.
I tried to use the copy tool but the rotation of a curve on the sphere
could not produce the full spherical surface..
Is there an easy way to construct that kind of volume?
Thank you,
Seungil.
On Sat, Nov 23, 2013 at 12:29 AM, Enrique Escolano
escolano at cimne.upc.eduwrote:
If you create a surface defined only ‘by its boundary lines’ then the
shape of the surface must match these lines, but the inner shape is freely
created (by a kind of coons or bicubical interpolation). It shape won’t
necessarily be what you are expecting, e.g. won’t be spherical
You can create a perfect spherical surface by revolution with extrusion
(copy tool),
but you must know its revolution axis (two coordinates to define it), and
have some curve on the surface to be extruded (e.g. an arc)
If the ‘full surface’ doesn’t has the required lines as boundary, then you
can create a trimmed surface, trimming the ‘base surface’ with its boundary
lines.
*De:* gidlist-bounces at listas.cimne.upc.edu [mailto:
gidlist-bounces at listas.cimne.upc.edu] *En nombre de *Seungil Kim
*Enviado el:* viernes, 22 de noviembre de 2013 16:11
*Para:* gidlist at listas.cimne.upc.edu
*Asunto:* [GiDlist] how to create a surface on a sphere
Dear Sir,
I have four curves on a unit sphere.
When I used "Create NURBS surface" to create a surface bounded by the four
curves,
I expected a surface on a surface but it doesn't seem to be a part of
sphere..
Is it possible to create a spherical surface when the four bounding curves
are on a sphere?
Seungil.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131125/821e7cb7/attachment.htm
of the pyramid.
surface.
Thank you,
Seungil.
(copy tool),
lines.
Dear Sir,
curves,
sphere..
are on a sphere?
Seungil.
