[GiDlist] Error in constructor
Seungil Kim
[GiDlist] how to create a surface on a sphere
Post by Seungil Kim »
Thank you for your reply.
Actually, what I would like to do is to make a volume
which is obtained by cutting a pyramid with a sphere centered at a vertex
of the pyramid.
So the five sides of the volume are on planes but one is a spherical
surface.
I tried to use the copy tool but the rotation of a curve on the sphere
could not produce the full spherical surface..
Is there an easy way to construct that kind of volume?
Thank you,
Seungil.
On Sat, Nov 23, 2013 at 12:29 AM, Enrique Escolano
escolano at cimne.upc.eduwrote:
If you create a surface defined only ‘by its boundary lines’ then the
shape of the surface must match these lines, but the inner shape is freely
created (by a kind of coons or bicubical interpolation). It shape won’t
necessarily be what you are expecting, e.g. won’t be spherical
You can create a perfect spherical surface by revolution with extrusion
(copy tool),
but you must know its revolution axis (two coordinates to define it), and
have some curve on the surface to be extruded (e.g. an arc)
If the ‘full surface’ doesn’t has the required lines as boundary, then you
can create a trimmed surface, trimming the ‘base surface’ with its boundary
lines.
gidlist-bounces at listas.cimne.upc.edu] *En nombre de *Seungil Kim
*Enviado el:* viernes, 22 de noviembre de 2013 16:11
*Asunto:* [GiDlist] how to create a surface on a sphere
Dear Sir,
I have four curves on a unit sphere.
When I used "Create NURBS surface" to create a surface bounded by the four
curves,
I expected a surface on a surface but it doesn't seem to be a part of
sphere..
Is it possible to create a spherical surface when the four bounding curves
are on a sphere?
Seungil.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131125/821e7cb7/attachment.htm
I think that the easiest way is to create a volume of the pyramid, then
create a sphere centered at its vertex (Geometry-Create-Object-Sphere)
and then do a Boolean operation to have its intersection volume
(Geometry-Edit-Volume Boolean op-Intersection) and select both volumes.
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Seungil Kim
Enviado el: lunes, 25 de noviembre de 2013 11:13
Asunto: Re: [GiDlist] how to create a surface on a sphere
which is obtained by cutting a pyramid with a sphere centered at a vertex of
the pyramid.
surface.
I tried to use the copy tool but the rotation of a curve on the sphere could
Thank you,
Seungil.
On Sat, Nov 23, 2013 at 12:29 AM, Enrique Escolano escolano at cimne.upc.edu
wrote:
If you create a surface defined only 'by its boundary lines' then the shape
of the surface must match these lines, but the inner shape is freely created
(by a kind of coons or bicubical interpolation). It shape won't necessarily
be what you are expecting, e.g. won't be spherical
(copy tool),
If the 'full surface' doesn't has the required lines as boundary, then you
can create a trimmed surface, trimming the 'base surface' with its boundary
lines.
Enviado el: viernes, 22 de noviembre de 2013 16:11
Asunto: [GiDlist] how to create a surface on a sphere
Dear Sir,
curves,
sphere..
are on a sphere?
Seungil.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131125/da5f07cb/attachment.htm
Mark Smith
[GiDlist] Gid problem type display error
Post by Mark Smith »
I have a problem type which displayed OK in gid 7 and gid 9 but now the images wont display properly, Can I send the problem type to somebody rather than posting it ti the group?
I'm evaluating GiD 11 (used ver 7 & 9 for many years) where the type of geometry I will be dealing with is complex with multiple bodies created in solidworks. there will be many surfaces that overlay one another most likely only parts of the 2 surfaces are common, is there a way of pre-processing them in gid where features on each of the surfaces intersect both surfaces and leave only 1 common surface between 2 bodies. I could do this manually either in solidworks by splitting the surfaces or in GiD but would prefer an automatic method?
So that when I mesh I get a matching mesh at the common surfaces?
I use COMSOL and this recognises common faces with any detail on them being imposed on the common face with no duplicate surfaces, I’d like to be able to do the same in GiD if possible?
Mark
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131125/f1c5982b/attachment.htm
amelendo
Post by amelendo »
Hi Mark,
Send me the problemtype to my email adress amelendo at cimne.upc.edu , I
will take a look to your images problem.
Regarding overlay surfaces, GiD have the option
Geometry-Edit-Collapse-Model within a tolerance.
Adrià from GiDTeam
being imposed on the common face with no duplicate surfaces, I'd like
Mark
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131125/8a4e8579/attachment-0001.htm
amelendo
Post by amelendo »
I misunderstood Mark 's surface problem
Here is an example (2 independent boxes):
Solution for easy geometries goes trough:
First: Geometry-Edit-Intersection-Surfaces, 1:end
And after: Geometry-Edit-Collapse-Model within a appropriate tolerance.
If this actions are commonly used, you can do a macro to execute
automatically all steps of this process:
http://www.gidhome.com/component/manual/referencemanual/general_aspects/utilities_menu/tools/macros
(easy geometries = intersection it's well defined)
Adrià
El 25/11/2013 15:45, Adria Melendo escribió:
Hi Mark,
Adrià from GiDTeam
Mark
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131126/11e85547/attachment.htm
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131126/11e85547/attachment.png
