Page 2 of 3
[GiDlist] Set Materials
Posted: Mon Feb 20, 2012 7:58 pm
by Farzam-Student,STW, Arash
Yes, actually I have named it the same. I just wrote problem type in
the email for avoiding confusion. But still, I get the same error.
Arash
On Mon, Feb 20, 2012 at 12:35 PM, Enrique Escolano
escolano at cimne.upc.edu wrote:
In order to be automatically sourced by GiD, the name of the tcl file must
be "FLODEF V11.tcl "
(the same as the problemtype and .tcl extension)
From: "Farzam-Student,STW, Arash" farzam at ostatemail.okstate.edu
Sent: Monday, February 20, 2012 7:08 PM
Subject: Re: [GiDlist] Set Materials
I made a .tcl file in my problem type containing:
proc Example_GetNodesOfElementType { element_type } {
set nodes
  • foreach item [lindex [lindex [GiD_Info Mesh Elements $element_type
    -array] 0] 2] {
    lappend nodes {*}$item
    set nodes [lsort -integer -unique $nodes]
    return $nodes
    and in my .bas file,
    I have written
    *tcl(Example_GetNodesOfElementType Hexahedra)
    *NodesNum *NodesCoord
    to get the nodal coordinates all hexahedra elements. It is not working
    and it gives the error:
    Error in base file C:/Program Files/GiD/GiD 9.0.2/problemtypes/FLODEF
    V11.gid/FLODEF V11-post.bas at line number 3: Error in TCL expression:
    'invalid command name "Example_GetNodesOfElement_Type"'
    I would be happy to have your comment.
    Thank You,
    Arash Farzam
    On Tue, Feb 14, 2012 at 4:22 AM, Enrique Escolano
    No, you can't do a loop on the nodes of a type of elements with simple
    .bas
    commands.
    you can do the loop on the elements of a type, and inside write all its
    nodes, but then you will obtain the list of nodes of this kind of element,
    but with repetitions.
    to do this kind of special thinks you must go to Tcl scripting level. You
    can define a tcl procedure (inside a problemtype.tcl file it is
    automatically sourced) that
    return what you want (the list of nodes of a type of element unrepeated)
    You can invoke this Tcl procedure from the .bas file, with a
    *tcl(your_procedure) command, then the value returned by the procedure is
    directly printed in the output file.
    This is an example of the procedure you need to write in your
    set nodes
      -array] 0] 2] {
      return $nodes
      GiD_Info Mesh is a special GiD-Tcl command (you can see the its syntax at
      GiD Help (GiD Customization - Tcl/Tk extension)
      the rest is Tcl standard scripting language (can see documentation on
      Internet, and also in the help of Ramdebugger that is our Tcl/Tk editor
      and
      debugger), could open RamDebugger from the menu
      Data-Problemtype-Debugger...
      and in the .bas file you must write something like this:
      Hexahedra nodes:
      Quadrilateral nodes:
      *tcl(Example_GetNodesOfElementType Quadrilateral)
      Note that I prefixed the Tcl procedure with 'Example', to avoid conflicts
      with other possible Tcl procedure that could use the same name
      I recommend you to use a prefix or namespace related with the name of your
      problemtype.
      Note: you can obtain multiple .dat output files, writting multiple .bas
      templates. a increasing number if added to the name of each .dat file (and
      templates are evaluated sorted alphabetically by its name)
      Sent: Tuesday, February 14, 2012 12:45 AM
      Thank You very much,
      I have another qustion. I have two types of elements, hexahedron and
      rectangular. Can I set element type for each one and loop the nodes of
      each one? I want to have all the nodes of hexahedron elements only in
      one file and all the nodes of the rectangular elements only in another
      file.
      Best Regards,
      Arash
      On Wed, Feb 1, 2012 at 4:37 AM, Enrique Escolano escolano at cimne.upc.edu
      wrote:
      You can do two loops, and inside take in account only the kind of
      material
      you want
      And you can have in the material a hidden field, named for example
      'class',
      to identify its category
      MATERIAL:xxx
      Question:class
      Value:soil
      State:hidden
      END MATERIAL
      *loop materials
      *if(strcmp(Matprop(class),"soil")==0)
      write its properties
      *endif
      *end materials
      *loop materials
      *if(strcmp(Matprop(class),"concrete")==0)
      *endif
      *end materials
      Sent: Tuesday, January 31, 2012 10:05 PM
      Subject: [GiDlist] Set Materials
      I have two kinds of materials in my code: soil materials and concrete
      materials. Is there a way to ask GiD to loop only soil materials at
      one stage and loop concrete materials at another time in the .bas file
      instead of having the command Loop materials which will cover all
      soils and concretes? Can I use the set command to select only the soil
      / concrete materials?
      Thank You,
      Arash
Posted: Tue Feb 21, 2012 12:06 pm
I attach a simple problemtype that works well
Sent: Monday, February 20, 2012 7:58 PM
Arash
set nodes
    -array] 0] 2] {
    return $nodes
    I have written
    Thank You,
    Arash Farzam
    .bas
    commands.
    element,
    set nodes
[GiDlist] Remove dead elements from results visualisation
Posted: Thu Feb 23, 2012 4:48 pm
by Jose Munoz
Dear GID team,
I am trying to run an analysis where some of the elements are
progressivley "killed". I would like to show results only for those
elements that are still "alive", and completely remove from the
visualisation those that are "dead". Is there a way to do this?
Many thanks,
Jose
Jose J Munoz, http://www-lacan.upc.es/munoz/
Laboratori de Càlcul Numèric (LaCàN)
Dep. Matemàtica Aplicada III
C/ Comte d'Urgell, 187, Room 1D012
Campus Urgell UPC, Edifici EUETIB
E-08036 Barcelona, Spain
j.munoz at upc.edu, Skype: josej.munoz, Tel. + 34 93 413 7253
Posted: Fri Feb 24, 2012 12:22 pm
by miguel
to do this you have three options:
1- do not write results for the 'dead elements'. When doing a c.fill,
elements with no results will not be drawn;
2- write a new mesh for each time step with the 'dead elements' removed;
3- write a 'deformation' result so that the nodes of the 'dead elements'
fall 'outside' the current view, i.e. are moved far away.
Miguel Pasenau
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Jose Munoz
Enviado el: jueves, 23 de febrero de 2012 16:48
Asunto: [GiDlist] Remove dead elements from results visualisation
Dear GID team,
Many thanks,
Jose
Posted: Mon Feb 27, 2012 11:12 pm
I use the exact same problem type that you emailed me, but still, I
get the error:
V11.gid/FLODEF V11-z.bas at line number 2: Error in TCL expression:
'info Mesh Elements Elemtype ?first? ?last? ?-sublist? with
first,last0'
Do you know what the reason might be for this error?
Thank You,
Arash
On Tue, Feb 21, 2012 at 5:06 AM, Enrique Escolano
----- Original Message ----- From: "Farzam-Student,STW, Arash"
Arash
set nodes
    -array] 0] 2] {
    return $nodes
    I have written
    Thank You,
    Arash Farzam
    .bas
    commands.
    element,
    set nodes
Posted: Tue Feb 28, 2012 10:47 am
The problem is that your GiD version 9.0.2 is old, and the command GiD_Info
Mesh of this versions don't support the syntax -array I've used.
Download the last GiD developer version 10.2.1.d from our web
http://www.gidhome.com/download/developer-versions
Sent: Monday, February 27, 2012 11:12 PM
get the error:
first,last0'
Thank You,
Arash
Arash
must
set nodes
    -array] 0] 2] {
    return $nodes
    I have written
    Thank You,
    Arash Farzam
    .bas
    commands.
    element,
    You
    unrepeated)
    is
    set nodes
Posted: Wed Feb 29, 2012 9:55 pm
Will I be able to use the version 10.2.1.d with my same software key?
On Tue, Feb 28, 2012 at 3:47 AM, Enrique Escolano
get the error:
first,last0'
Thank You,
Arash
Arash
must
set nodes
    -array] 0] 2] {
    return $nodes
    I have written
    Thank You,
    Arash Farzam
    .bas
    commands.
    element,
    You
    unrepeated)
    is
    set nodes
Posted: Thu Mar 01, 2012 9:15 am
by abelcs
The password for version 10 is valid for all the 10.x.x versions, but the
password change between main versions (from 9 to 10, for example).
ABEL
Abel Coll Sans - Civil Engineer
Ofice c-2, C1 building - Campus Nord UPC
Gran Capità s/n, 08034 Barcelona
Enviado el: miércoles, 29 de febrero de 2012 21:55
Asunto: Re: [GiDlist] Set Materials
On Tue, Feb 28, 2012 at 3:47 AM, Enrique Escolano escolano at cimne.upc.edu
GiD_Info Mesh of this versions don't support the syntax -array I've used.
get the error:
first,last0'
Thank You,
Arash
Arash
file must be "FLODEF V11.tcl "
proc Example_GetNodesOfElementType { element_type } { set nodes
    $element_type -array] 0] 2] { lappend nodes {*}$item } set nodes
    [lsort -integer -unique $nodes] return $nodes }
    I have written
    *tcl(Example_GetNodesOfElementType Hexahedra) *NodesNum *NodesCoord
    working and it gives the error:
    9.0.2/problemtypes/FLODEF V11.gid/FLODEF V11-post.bas at line number 3:
    Thank You,
    Arash Farzam
    simple .bas commands.
    all its nodes, but then you will obtain the list of nodes of this
    kind of element, but with repetitions.
    You
    automatically sourced) that return what you want (the list of
    unrepeated)
    procedure is directly printed in the output file.
Posted: Thu Mar 01, 2012 11:02 am
No, the password of versions 10.x is different of the passwords of version 9.x. Could try GiD 10.x with a trial one month password
You can restrict the use of GiD-Tcl commands to the ones available on GiD 9.0.2 (see Help-Customization-TclTk extension)
in this version you can't use the -array flag of the command
GiD_Info Mesh Elements $element_type -array
but for example could use
GiD_Info Mesh Elements $element_type -sublist
this is the procedure modified to work also with your version:
set nodes
  • foreach item [GiD_Info Mesh Elements $element_type -sublist] {
    lappend nodes {*}[lrange $item 1 end-1]
    return $nodes
    Sent: Wednesday, February 29, 2012 9:55 PM
    get the error:
    first,last0'
    Thank You,
    Arash
    Arash
    must
    set nodes
Posted: Mon Mar 05, 2012 10:40 pm
Thank You for the update,
Is this new code (with the sublist being used instead of array) still
supposed to write the nodes? I tried it and it gave me just one single
number instead of the list of the nodes.
Thank You
On Thu, Mar 1, 2012 at 4:02 AM, Enrique Escolano escolano at cimne.upc.edu wrote:
Password Alert! This message may contain a request for your password. NEVER
SEND OR RESPOND TO E-MAIL REQUESTS FOR YOUR PASSWORD. For questions about
this alert, please contact the IT HelpDesk at 405-744-4357 or email
helpdesk at okstate.edu.
set nodes
    return $nodes
    GiD_Info
    get the error:
    first,last0'
    Thank You,
    Arash
    Arash
    must
    set nodes
