[GiDlist] STEP file import
[GiDlist] observation points for results
You can use
View Results-Graph-Point evolution
And enter the x,y,z coordinates of the point (that must be inside of some element)
And you will get its interpolated result along all time steps.
During the selection you can click the right mouse button, and in the contextual menu change the mode to pick existing nodes (Join Ctrl-a / Select nodes) or pick coordinates of points to be interpolated.
The graph values could be exported to a text file with Files-Export-Graph
Or from the graphs window you can show a table with the selected graph values, and use copy/paste of these values (e.g. to transfer the values to MS Excel)
De: gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Julia Camargo
Enviado el: lunes, 23 de junio de 2014 20:33
Asunto: [GiDlist] observation points for results
Hi GiD team,
I would like to export my results in some points that are not mesh nodes. I have the coordinates of those points. Is there a way to get the results in those "observation points"?
Thank you,
Julia
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140625/a4366bd3/attachment-0001.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140625/a4366bd3/attachment-0003.jpeg
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140625/a4366bd3/attachment-0004.jpeg
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140625/a4366bd3/attachment-0005.jpeg
HEMMI, Shigeru
[GiDlist] Does "contour fill" works on GID 11.1.9.d?
Post by HEMMI, Shigeru »
Dear Anna Monros and Enrique Escolano,
I removed 3 files in the AppData\Roaming\GiD
.GiDPostPreferences.ini
gid.ini
gid.preferences
then restart GiD, it works fine.
Seems that "fast visualization mode" or "safe mode" is not a problem.
Thanks for the support.
HEMMI, Shigeru
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140626/1d65a4ec/attachment-0001.png
Julia Camargo
Post by Julia Camargo »
Hi Enrique,
I am following all the steps you recommended:
element)
But I keep receiving the message that "the point lies outside the set". I
did a simple example to verify if my point was inside an element. As you
can see in the attached picture, the point I have chosen (0.5,0.5,0.5)
certainly is inside some element. Even so, the message appears. But if I
put the coordinate of a node, then I receive a result. What am I doing
wrong?
Thank you again,
Julia
2014-06-25 10:45 GMT-03:00 Enrique Escolano escolano at cimne.upc.edu:
You can use
element)
MS Excel)
gidlist-bounces at listas.cimne.upc.edu] *En nombre de *Julia Camargo
*Enviado el:* lunes, 23 de junio de 2014 20:33
*Asunto:* [GiDlist] observation points for results
Hi GiD team,
Thank you,
Julia
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140710/f5707aff/attachment-0001.htm
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140710/f5707aff/attachment-0003.jpg
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140710/f5707aff/attachment-0004.jpg
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140710/f5707aff/attachment-0005.jpg
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140710/f5707aff/attachment-0001.png
Send me the example.
Enviado el: jueves, 10 de julio de 2014 15:52
Asunto: Re: [GiDlist] observation points for results
Hi Enrique,
But I keep receiving the message that "the point lies outside the set". I did a simple example to verify if my point was inside an element. As you can see in the attached picture, the point I have chosen (0.5,0.5,0.5) certainly is inside some element. Even so, the message appears. But if I put the coordinate of a node, then I receive a result. What am I doing wrong?
Thank you again,
Julia
You can use
Hi GiD team,
Thank you,
Julia
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140711/3d333739/attachment-0001.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140711/3d333739/attachment-0003.jpeg
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140711/3d333739/attachment-0004.jpeg
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140711/3d333739/attachment-0005.jpeg
