I tried to download the beta version but I encountered a problem and I could
not succeed it. If it is possible, could you send me the version to my mail
adress
Thanks for your help
PS: Also I could not download the manuals in pdf format. Could you send them
either.
First, It's a illegal syntax to cross two loops or if - endif blocks
And you use some as:
*if(N0)
*format "%11i"
*LayerName
*loop elems *OnlyInLayer
*ElemsNum
*end if
*end elems
It's not valid to close the endif before to close the end elems
A valid sytax is:
*if(N0)
*format "%11i"
*LayerName
*ElemsNum
*end elems
*end if
Other bug, you use *format "%11i" before to print *Layername, this format is
not valid for a string, you probably try
to print *ElemsNum with this integer format, must use this format order just
before *ElemenNum
Other efficiency detail: If you do not require to count the number or
elements of a layer,
and only need to know if has elements, instead
*set var N=0
*if(ElemsLayerNum0)
*set var N=operation(N+1)
*end if
*end elems
Why check if ElemsLayerNum is 0 ?, and also, it,s much more efficient exit
the loop with break,
for example:
*set var N=0
*set var N=1
*break
*end elems
About the last problem: are written all nodes for each layer, it's a GiD bug.
It not works correctly the modifier *onlyinlayer
for a loop nodes.
This bug is corrected for the next 7.4.5b beta version, but until this
version is available, can avoid this bug chequing
with a *if the node layer
*loop layers
*set Layer *LayerName *nodes
*LayerName
*loop nodes
*if(LayerNum==NodesLayerNum)
*format "%10i"
*NodesNum
*endif
*end nodes
*end layers
Note than instead *loop nodes *OnlyInLayer only is used *loop nodes , and is
added the *if(LayerNum==NodesLayerNum)
I attach the corrected *.bas compressed
Sent: Tuesday, November 04, 2003 3:17 PM
Subject: [GiDlist] element set and node set
Hi Enrique,
I tried to create element and node set by using layer utility.
I wrote follwing bas file to get sets.
ELEMENT SETS
*loop layers
*set Layer *LayerName *elems
*set var N=0
*if(ElemsLayerNum0)
*end if
*end elems
*if(N0)
*format "%11i"
*LayerName
*ElemsNum
*end if
*end elems
*end layers
NODE SETS
*loop layers
*format "%10i"
*LayerName
*NodesNum
*end nodes
*end layers
I encountered two problems. First one is that I could not get the triangle
element in the element sets. Secondly, although I set different nodes in
different subsets, it gives all nodes in the mesh generation for each
layer.
Thanks a lot.
Ali OK
[GiDlist] element numbering
Hi Enrique,
I want to set the one side of the element as a side set. I tried to do it
with layer option but it does not work. Is there any other ways to set a
element side in GID.
You probably need to define a condition "over face elements",
Read the online manual help about the conditions file
http://www.gidhome.com/support/gid_15.subst#SEC209
To use this information in the bas file, read the documentation about this
commands:
*set cond, *globalnodes. *localnodes
Sent: Friday, November 07, 2003 2:53 PM
Subject: Re: [GiDlist] element set and node set
Hi Enrique,
commands:
Hi Enrique,
