[GiDlist] Can I create structured mesh with only points?
Posted: Mon Apr 28, 2003 10:54 am
MensajeThis is a small geometry example to obtain a structured hexahedral mesh. To create the mesh use Meshing-generate
with any mesh size (this size is avoided because all number of mesh divisions is set by the structured mesh info)
GiD only generate hexahedrals in structured mode, it requires to divide the model in 6-faceted volumes), and then assign
meshing structured volumes (and the number of divisions in each three directions).
Sent: Friday, April 25, 2003 11:29 PM
Subject: Re: [GiDlist] Can I create structured mesh with only points?
Dear GiD Teams,
Thank you for all useful answer, Thank also for Dr.Ribo. I am very new to tcl and it's so important to have all of your guidances. Anyway, it means people need to use hex elements in transferring results from Finite Volume (in case they will not modify GiD), can anybody provide me a case study for this.
Adisorn
Sent: Friday, April 25, 2003 5:04 PM
Subject: RE: [GiDlist] Can I create structured mesh with only points?
If the nodes follow a given ordering and there is only one block of elements, the code that
you need to program to create the elements is really trivial. I am sure that you can program
it in less that 20 lines of code (of TCL of course). Ask for more help if you are not able to do it.
De: gidlist-admin at gatxan.cimne.upc.es [mailto:gidlist-admin at gatxan.cimne.upc.es] En nombre de Adisorn Owatsiriwong
Enviado el: viernes, 25 de abril de 2003 12:49
Para: GiD
Asunto: [GiDlist] Can I create structured mesh with only points?
Dear GiD Team,
I need to transfer results from finite difference (finite volume) to GiD post.The results only provide at node and I require no element to make such computations. It's more convenient to transfer these results to node directly. Can I create a structured mesh with only points instead of hex elements? I tried but it failed,and finally I got unstructured mesh.
Bests,
Adisorn
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030428/431d4a5e/attachment.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030428/431d4a5e/attachment.bin
Dear GiD Teams,
Adisorn
Para: GiD
Dear GiD Team,
Bests,
Adisorn
