Page 2 of 2
[GiDlist] GiDPost library
Posted: Thu Jan 22, 2004 5:12 pm
Can read more information, and download the source code (and compiled library for Windows) on our web page
http://www.gidhome.com/support/gidpost.subst
Sent: Thursday, January 22, 2004 2:46 PM
Subject: RE: [GiDlist] GiDPost library
Hi miguel,
I have been searching the GID help files for description of how to use the GiDPost library, since I'm using huge ASCII result file. However I found nothing, could you please show me where i can find more information about it?
Khaled
At 05:51 AM 1/22/2004, you wrote:
The binary format is platform independent, so the binary files created in
windows can ver read in linux, silicon, etc. And viceversa.
[mailto:gidlist-admin at gatxan.cimne.upc.es] En nombre de Malte Neumann
Enviado el: jueves, 22 de enero de 2004 11:23
Asunto: Re: [GiDlist] GiDPost library
just a follow-up question about binary postprocess files:
If I use GiD on a Windows System and my calculation program runs on a Linux or
Unix System, is it possible to use binary postprocess files, or is the format
of the binary files machine dependent.
Thanks for your advice.
Malte
On Thu, Jan 22, 2004 at 10:47:09AM +0100, Enrique Escolano wrote:
And advantage is for analyis with a very big result file, instead to
write an ASCII file is possible to write a smaller compressed binary
(also is faster readed). Al another advantage is to avoid errors
writting the postprocess file, specially for a binary format!!
And if the format is changed in a future, the library is updated by our
team, and the external developer only need to update an re-compile.
Malte Neumann
Institut fuer Baustatik / Institute of Structural Mechanics
Prof. Dr.-Ing. Ekkehard Ramm
Universitaet Stuttgart / University of Stuttgart
Pfaffenwaldring 7, D-70550 Stuttgart, Germany
mailto:neumann at statik.uni-stuttgart.de phone: ++49-711-685-6121
http://www.uni-stuttgart.de/ibs/members/neumann/ fax: ++49-711-685-6130
GiDlist at gid.cimne.upc.es http://gid.cimne.upc.es/mailman/listinfo/gidlist
Khaled Obeidat
Research Engineer
EMAG Technologies, Inc.
www.emagtechnologies.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040122/5cb2da7f/attachment.htm
[GiDlist] DEPENDENCIES & #N#
Posted: Fri Feb 06, 2004 9:37 am
by VSayako Willy
Hi Enrique & GiD team
How can we use the command DEPENDENCIES with the
following fields:
QUESTION:Lrange(A1,A2,A3)
VALUE:#N# 3 1 2 3
I tried as usual way but didn't work out.
Do you Yahoo!?
Yahoo! Finance: Get your refund fast by filing online.
http://taxes.yahoo.com/filing.html
Posted: Fri Feb 06, 2004 11:03 am
by Jorge Suit Pérez Ronda
Hi, if you want to modify the vale of table field ussing a DEPENDENCIES
you should enclose the value between ", for instance
question: Change#CB#(3,6)
value: 3
dependencies: (3, restore, Lrange, "#N# 3 1 2 3") \
(6, restore, Lrange, "#N# 6 1 2 3 4 5 6")
question: Lrange(A1,A2,A3)
value: #N# 3 1 2 3
regards,
Jorge Suit
following fields:
VALUE:#N# 3 1 2 3
Do you Yahoo!?
Posted: Mon Feb 09, 2004 5:41 am
by VSayako Willy
Hi Jorge Suit
I have tried as your advice but it's still not
working. I used GiD 7.2
Regards.
value: 3
6")
value: #N# 3 1 2 3
regards,
Jorge Suit
the
following fields:
VALUE:#N# 3 1 2 3
Do you Yahoo!?
online.
Do you Yahoo!?
Posted: Mon Feb 09, 2004 2:21 pm
Please, try the last beta version 7.4.6b
On Mon, 2004-02-09 at 05:32, VSayako Willy wrote:
Hi Jorge Suit
Regards.
value: 3
6")
value: #N# 3 1 2 3
regards,
Jorge Suit
the
following fields:
VALUE:#N# 3 1 2 3
Do you Yahoo!?
online.
Do you Yahoo!?
