[GiDlist] triangles, tetrahedra and nodes
VSayako Willy
[GiDlist] Thank to Miguel for the Nodal ball information
Post by VSayako Willy »
Thanks much Miguel..for the information..
--- Miguel Pasenau miguel at cimne.upc.edu wrote:
Well, in post there is the 'points' display style
which draws points or
spheres at the nodes (Options-Geometry-Point
options).
But to achieve what you see at your picture, the
only way I see is to create
'point' elements on your nodes and 'line' elements
on your edges.
Something like this (just 2 balls and 1 edge):
MESH "balls" dimension 3 Elemtype Point Nnode 1
Coordinates
1 0.0
2 1.0
End coordinates
Elements
1 1
2 2
End elements
MESH "bars" dimension 3 ElemType Lineas Nnode 2
Coordinates
End Coordinates
Elements
1 1 2
End Elements
If you want to change the balls and lines
visualization, just use the
"Options-Geometry-Points options" and
"Options-Geometry-Line Options".
reagrds
[mailto:gidlist-admin at gatxan.cimne.upc.edu] En
nombre de VSayako Willy
Enviado el: viernes, 14 de octubre de 2005 12:26
Asunto: [GiDlist] How to display a node as a ball
Hi GiD Team
I found that some of the User displayed the
mesh
with a nice nodal ball.. I have tried in the Render
customize but it dind't work.. How would you do that
I herewith attached the file that I found it
Regards..
--- Andreas Hauck
andreas.hauck at lse.eei.uni-erlangen.de wrote:
is there a possibility in GiD to visualize scalar
and vectorial results
with logarithmic scaling (e.g. acoustic pressure)?
Andreas
_/ _/_/ _/_/_/ Friedrich Alexander
Universität Erlangen
_/ _/ _/ _/ Lehrstuhl für
Sensorik
_/ _/ _/ Paul-Gordan-Str.
3-5,
D-91052 Erlangen
_/ _/_/ _/_/_/
_/ _/ _/ Friedrich Alexander
University Erlangen
_/ _/ _/ _/ Department of
Sensor Technology
_/_/_/ _/_/ _/_/_/ Paul-Gordan-Str. 3-5,
D-91052 Erlangen
M.Sc. Andreas Hauck
email.: andreas.hauck at lse.eei.uni-erlangen.de
url. : http://www.lse.uni-erlangen.de
tel. : (+49)-9131-85-23147
fax. : (+49)-9131-85-23133
Yahoo! Music Unlimited
Access over 1 million songs. Try it free.
http://music.yahoo.com/unlimited/
Yahoo! Mail - PC Magazine Editors' Choice 2005
http://mail.yahoo.com
rafadoig at hiroshima-u.ac.jp
[GiDlist] coordinate system in pictures
Post by rafadoig at hiroshima-u.ac.jp »
does somebody know how to hide the coordinate system by plotting results in picture files like png or gif?
Thanks in advance
Rafael
VSayako Willy
Hi Miguel
I tried what you gave me an example but it didn't
work out..especially the .msh file and I never saw
such commands you have given here.. Any further
suggestion??
options).
on your edges.
Coordinates
1 0.0
2 1.0
End coordinates
Elements
1 1
2 2
End elements
Coordinates
End Coordinates
Elements
1 1 2
End Elements
reagrds
Hi GiD Team
mesh
Regards..
--- Andreas Hauck
Andreas
Sensorik
3-5,
D-91052 Erlangen
_/ _/_/ _/_/_/
University Erlangen
Sensor Technology
D-91052 Erlangen
M.Sc. Andreas Hauck
There is a "dark" command to show/hide this axes:
escape escape escape view hardcopy options _showaxes
Sent: Saturday, October 15, 2005 6:16 AM
Subject: [GiDlist] coordinate system in pictures
Thanks in advance
Rafael
Mihai TEODORESCU
[GiDlist] Probleme in reporting higher entities for a point
Post by Mihai TEODORESCU »
I'm using Gid 7.6.0b. When I make Utilities - list - Points and pick a point belonging to 3 lines I get the folowing result:
POINT
Num: 3 HigherEntity: 3 conditions: 1 material: 0
LAYER: Layer0
Coord: 0.000000 5.000000 0.000000
END POINT
POINT (more)
Higher entities points: 1 4 11
END POINT
But I think it should be lines instead of points in: Higher entities points: 1 4 11
Mihai TEODORESCU
Yes, the correct message must be: "Higher entities lines: 1 4 11"
Thanks for your bug report
From: "Mihai TEODORESCU" mihai.teodorescu at prevost-industries.com
Sent: Tuesday, October 18, 2005 4:48 PM
Subject: [GiDlist] Probleme in reporting higher entities for a point
POINT
LAYER: Layer0
END POINT
POINT (more)
END POINT
Mihai TEODORESCU
Martin Meiler
[GiDlist] Problems with Mesh-Generation
Post by Martin Meiler »
Hi everybody,
when creating a mesh, GiD complains about
"There are elements with negative jacobian in some node in surface 1 mesh"
"There are elements with negative jacobian in some node in surface 2 mesh"
Steps to reproduce this behaviour:
# creating geometries
# - create two rectangles
rectangle 0,0 8e-4,1e-2
rectangle 0,1e-2 8e-4,46e-2
# - create a quarter of a circle
utilities copy lines DoExtrude surfaces MaintainLayers Rotation FJoin 2
TwoDim -90 2 escape
# set import tolerance
utilities variables ImportTolerance 1e-6
# collapse model
utilities collapse model yes
# renumber all entities
utilities renumber yes
# setup the mesh
# - structured surfaces of the rectangles
Meshing Structured Surfaces 1 2 3 escape 4 2 4 escape 3 1 3 6 escape
# - select quadratic elements
Meshing quadratic Quadratic
# generate mesh
Meshing Generate 4e-3
When creating the mesh, the messages about the elemtents with negative
jacobian appeear.
This doesn't happen, when i don't use structured surfaces.
But the question is: If GiD already knows about elements defined in the
wrong direction meaning clockwise, why does he not correct the wrong
elements instead of telling me that there have been mistakes along the
element definition.
Martin Meiler
_/ _/_/ _/_/_/ Friedrich Alexander Universität Erlangen
_/ _/_/ _/_/
_/ _/ _/ _/ Department of Sensor Technology
_/_/_/ _/_/ _/_/_/ Paul-Gordanstr. 5, 91052 Erlangen, Germany
Dipl.-Ing. Martin Meiler
tel.: (+49)-9131-85-23140
fax.: (+49)-9131-85-23133
abelcs
Post by abelcs »
Which GiD version are you working with?
Abel Coll
From: "Martin Meiler" Martin.Meiler at lse.eei.uni-erlangen.de
Sent: Wednesday, October 19, 2005 9:40 AM
Subject: [GiDlist] Problems with Mesh-Generation
Hi everybody,
TwoDim -90 2 escape
# collapse model
# setup the mesh
# generate mesh
jacobian appeear.
element definition.
Martin Meiler
_/ _/_/ _/_/
Martin Meiler
i'm working with the latest GiD beta 7.6.0b on an SuSE linux machine.
Bye Martin
Abel Coll
Hi everybody,
TwoDim -90 2 escape
# collapse model
# setup the mesh
# generate mesh
jacobian appeear.
element definition.
Martin Meiler
_/ _/_/ _/_/
_/ _/_/ _/_/
abelcs
Post by abelcs »
Thanks for notifying us this behaviour. It is now corrected, so it will be
available to you in the next beta version, that provably will be ready in
this week.
Regards.
ABEL
Sent: Wednesday, October 19, 2005 2:51 PM
Subject: Re: [GiDlist] Problems with Mesh-Generation
Bye Martin
Abel Coll
Hi everybody,
mesh"
mesh"
TwoDim -90 2 escape
# collapse model
# setup the mesh
# generate mesh
jacobian appeear.
element definition.
Martin Meiler
_/ _/_/ _/_/
_/ _/_/ _/_/
