How to plot deformed mesh on top of the undeformed one?
The command I am using:
Result "Displacements" "Load Analysis" 1 Vector OnNodes
plots deformed shape with no mesh.
Zdzislaw
[GiDlist] Deformed+undeformed mesh plot
[GiDlist] Visualization of fields at Prism Gauss Points
I am having problems when trying to visualize fields defined at Gauss
Points of prism elements if 6 Gauss Points are used. The results shown
by "Contour Fill" or ""Smooth Contour Fill" are completely divergent
from what is written in the post-processing files (for instance, the
density field in attached files has values around 1.0 and those commands
shown a field with MIN=-17.893 and MAX=12.153).
I am using the last GiD version for Linux 64 and I am attaching a small
example that cause the problem described above here. Is it a software
bug or my postprocess files are incorrect?
Thank you in advance,
Claudio
_____________________________________________________
Claudio Alessandro de Carvalho Silva, Dr. Eng. (#329333)
CAE Solutions
Thorus Scisoft - www.thorus-scisoft.com.br
Fone:+55 19 3705-4002
This message is intended solely for the use of its addressee and may contain
privileged or confidential information. If you are not the addressee you
should not distribute, copy or file this message. In this case, please
notify
the sender and destroy its contents immediately.
Esta mensagem é para uso exclusivo de seu destinatário e pode conter
informações privilegiadas e confidenciais. Se você não é o destinatário, não
deve distribuir, copiar ou arquivar a mensagem. Neste caso, por favor,
notifique o remetente da mesma e destrua imediatamente a mensagem.
Type: model/mesh
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100302/d3fa1773/attachment.msh
Type: application/x-dtbresource+xml
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100302/d3fa1773/attachment.bin
Claudio
CAE Solutions
notify
Type: model/mesh
