Dear Code_Bright Community,
I'm trying to use the law "Intrinsic permeability depending on an embedded aperture", referring to the normal strain to the discontinuity (ICL=7, ITYCL=4).
The user's guide it's perfectly clear about the increase in permeability but I cannot understand well the criteria used to define the normal strain to the discontinuity and the discontinuity itself.
As far as I understood, it uses vertical strain and it doesn't depend on a "real" discontinuity.
I wanted to model vertical fractures, so I solved the problem introducing an initial anisotropy (alfa = 90) and by this way, the model seems to use the horizontal strain as normal strain. However, by this way, I should define the direction of the discontinuity beforehand. Is it correct?
Would it be kindly possible to have other details about this model?
Is there a way to relate the reference strain to the plastic strain?
Is there a reference about this model?
Kind regards,
Domenico
Intrinsic permeability issue (ITYCL=4)
Moderator: CODE_BRIGHT Team
