[GiDlist] quadratic elements with straight edges
zwozniak at cogeco.ca
Post by zwozniak at cogeco.ca »
Hi All,
I have a 3D oval shaped model and I am using mesh with quadratic elements. For such a geometry GiD generates elements
with curved edges. How to generate mesh with quadratic elements having straight edges?
Zdzislaw
This option not exists internally, but we provided a predefined macro that
do exactly this (move quadratic nodes to align them) from Tcl scripting.
You could enable this macro with: Utilities-Tools-Macros...
select the 'Align Quadratic Nodes' macro, press the 'right-mouse' button to
open the contextual menu and use 'In toolbar', then its icon will be shown
in the 'macros toolbar'.
Press this button and all quadratic nodes will be aligned.
Sent: Wednesday, November 02, 2011 2:23 PM
Subject: [GiDlist] quadratic elements with straight edges
Hi All,
straight edges?
Zdzislaw
Farzam-Student,STW, Arash
[GiDlist] Showing Post Process Values in Labels on the conto
Post by Farzam-Student,STW, Arash »
Dear All,
I have the contour fill results of a mass in post processing part. I make
sections of that, and I want to label the values of the result at some
nodes on that section. Please let me know what command I should use. I use
View/ Label, but it gives the node numbers instead of the value.
Best Regards,
Arash Farzam
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20111102/f06dad72/attachment.htm
Draw some result, use:
View-Label-Select-Res
and the select the nodes where you want to see a label with its result
Sent: Wednesday, November 02, 2011 7:04 PM
Subject: [GiDlist] Showing Post Process Values in Labels on the contour
Dear All,
I have the contour fill results of a mass in post processing part. I make sections of that, and I want to label the values of the result at some nodes on that section. Please let me know what command I should use. I use View/ Label, but it gives the node numbers instead of the value.
Best Regards,
Arash Farzam
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20111102/bd565014/attachment.htm
Post by miguel »
just after doing the contour fill of the result you want to see, right
clicking over the graphical window, select "Label--Select--.Res" and
select the nodes whose results you want to display. The label will display
the value of the result on that node.
If you the change the result used for the contour fill, the label will
change accordingly.
best reagrds,
Miguel Pasenau
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de
Enviado el: miércoles, 02 de noviembre de 2011 19:04
Asunto: [GiDlist] Showing Post Process Values in Labels on the contour
Dear All,
Best Regards,
Arash Farzam
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20111107/05283e78/attachment.htm
