Soil Pile interaction in THM process
khagendra
Post by khagendra »
I am a graduate student in civil engineering and trying to make a project on soil-pile interaction in THM coupling. While a simulate my project without any load on pile, I can read outputs, whenever i apply some vertical loading on pile, I am getting " Gauss Point Error". How can I solve this problem. Besides this I am unable to generate a structures mesh ( i.e. i want to create a mesh with all rectangles instead of triangular elements).
PS: I am using a student version (GID 12.0.7) right now.
Thank you,
khagendra
THM Coupling Practice with load on pile.gid.zip
(131.25 KiB) Downloaded 354 times
THM Coupling Practice.gid.zip
(2.7 MiB) Downloaded 304 times
Re: Soil Pile interaction in THM process
You can mesh with quadrilaterals with
Mesh->Element type->Quadrilateral
and select the surfaces
this generate unstructured quadrilaterals, to generate structured ones set
Mesh->Structured->Surfaces->Assign number of cells
the select the surfaces
and then the number of divisions of each two directions (select the lines with these divisions)
khagendra
Post by khagendra »
Thank you for the help regarding meshing. Could please help me the simulation problem that I'm facing, i.e., the "Gauss point error" while I try to simulate with external loading on pile under the Thermo hydro mechanical process.
Thank you in advance
Khagendra
khagendra
Post by khagendra »
Thanks for your help regarding the meshing. Could you please check for the loading criteria in Thermo-hydro-mechanical process.
Thank you,
Khagendra
I can not aid you with the calculation problem: I am not an user of Code_brigth
Try to have a look to the input and output files of Code_brigth, maybe you are able to detect something related with the error.
