Unable to save files
waseda
Contact:
Post by waseda »
I am trying to install GiD 12 on a laptop with Windows 10.
I was able to install the software program with no issue but when I try to use the software, I can't save any files. (Thus, I can't execute calculations). Note that when I selected "save" or "save as", the program seems freezed. Then I need to push Esc button.
I've re-install GiD several times (by different versions) but it doesn't work. (GiD is working just fine on a desktop machine with Windows 7. )
Can anyone help me fix the problem?
Kenji Furui
Waseda University
abelcs
Re: Unable to save files
Post by abelcs »
could you please indicate the exact version of GiD are you using? (12.x.y?). You can find this information in the Help->About menu
raymondmmcmaster
Post by raymondmmcmaster »
I am having the exact same problem , unable to save my files. GiD version I am using is GID13.0
We don't have any idea about the problem, it never happened in any of our machines.
Do you have some extra information? e.g:
It raise some error message in the lower message bar?
The 'Save as' window appear when GiD become frozen?
It responds to some user action? (it seems by the first topic that at least the 'cancel' button could be pressed)
It only happened with Windows 10? Which exact version of Windows 10? and it is x32 or x64?
There is new GiD 13.1.0d developer version available for download (Windows x32 and x64 platforms only)
http://www.gidhome.com/download/developer-versions
Try if the problem has been fixed in this version.
