[GiDlist] Meshing curved volumes
amit Dhankhar
Post by amit Dhankhar »
I am trying to mesh a simple geometry of the form of a spherical cap (
created by rotating an arc about its axis) but GID shows up some meshing
error. Creating spherical caps from boolean operations don't work either.
Here's how my geometry looks like-
[image: Inline image 1]
It was created by rotating this surface around it own axis (bounded by an
arc and a line)-
[image: Inline image 2]
As we can see, it shows up error saying 'two faces intersect'. Is there any
other way to mesh such volumes?
Amit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/fc518824/attachment-0001.htm
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/fc518824/attachment-0002.png
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/fc518824/attachment-0003.png
Try to fix some geometrical problem with Utilities-Repair
Try to set all default meshing option. In utilities preferences meshing press the Reset button
If it continue without mesh trying a reasonable mesh size then attach a zip with your model to have a look
De: gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de amit Dhankhar
Enviado el: viernes, 7 de noviembre de 2014 20:32
Asunto: [GiDlist] Meshing curved volumes
I am trying to mesh a simple geometry of the form of a spherical cap ( created by rotating an arc about its axis) but GID shows up some meshing error. Creating spherical caps from boolean operations don't work either.
Inline image 1
It was created by rotating this surface around it own axis (bounded by an arc and a line)-
Inline image 2
As we can see, it shows up error saying 'two faces intersect'. Is there any other way to mesh such volumes?
Amit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141110/9ba04a55/attachment.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141110/9ba04a55/attachment.jpeg
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141110/9ba04a55/attachment-0001.jpeg
amit Dhankhar
I tried the repair geometry option which just says "everything was ok" but
fails to mesh. I created my volume by rotating a 2-d curved surface about
its own axis. (which retains the original 2-d surface and creates extra
points and lines which I have to collapse later)
I have attached a zip file containing the simple model -
"nov13_curvedvol_original.gid" - volume created by the rotation which GID
fails to mesh. Could you tell me what else could be wrong in this one? I am
running 12.1.1d version of GID.
In another attempt, "nov13_curvedvol_mod.gid" - I wanted to get rid of
extra surfaces, lines and points so I deleted the original 2-d surface and
the extra lines and tried reconstructing the volume which gives out an
error. This file just has the curved surface and it's base surface (which
ideally should represent a bounded domain)
On Mon, Nov 10, 2014 at 12:26 PM, Enrique Escolano escolano at cimne.upc.edu
*De:* gidlist-bounces at listas.cimne.upc.edu [mailto:
gidlist-bounces at listas.cimne.upc.edu] *En nombre de *amit Dhankhar
*Enviado el:* viernes, 7 de noviembre de 2014 20:32
*Para:* gidlist at listas.cimne.upc.edu
*Asunto:* [GiDlist] Meshing curved volumes
arc and a line)-
Amit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141113/ed33f5e5/attachment-0001.htm
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141113/ed33f5e5/attachment-0002.jpg
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141113/ed33f5e5/attachment-0003.jpg
Type: application/x-gzip
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141113/ed33f5e5/attachment-0001.bin
Shaini Dilsha
[GiDlist] Soil Modeling - Mohr Coulomb and Hardening soil Mo
Post by Shaini Dilsha »
Dear Sir/Madam,
I need to know whether the GID software can use for deep excavation
analysis.
Could it able to work with following parameters;
*Defining soil parameters like;
- Mohr Coulomb and Hardening soil Model
- drain and undrain analysis
- C,phi,dialatency properties
- water level and etc.
*Stage constructions parameters and ect.
I am a beginner for this software and I am looking for analysis the deep
excavation. If anyone expert please reply to me. It will be great to me.
Thank you very much for your kind consideration,
Yours Sincerely,
Shaini Dilsha.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141117/42987377/attachment.htm
GiD itself don’t include any kind of simulation solver.
Simulation solvers are called ‘problemtypes’ in GiD terms (are like GiD-plugins for an specific calculation)
You can use for free code_bright, that is a geotechnical code developed at the Polytechnic University of Catalonia.
http://www.gidhome.com/gid-plus/modules/research-modules/63-codebright
De: gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Shaini Dilsha
Enviado el: lunes, 17 de noviembre de 2014 17:46
Asunto: [GiDlist] Soil Modeling - Mohr Coulomb and Hardening soil Model.
Dear Sir/Madam,
I need to know whether the GID software can use for deep excavation analysis.
* Mohr Coulomb and Hardening soil Model
* drain and undrain analysis
* C,phi,dialatency properties
* water level and etc.
I am a beginner for this software and I am looking for analysis the deep excavation. If anyone expert please reply to me. It will be great to me.
Yours Sincerely,
Shaini Dilsha.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141117/7583499f/attachment.htm
Shaini Dilsha
Dear Sir/Madam,
Thank You very much for your soon valuable reply. I could able to installed
CODE_BRIGHT version. So I'll try to work with that now.
Thank you very much again.
Yours Sincerely,
Shaini Dilsha.
On Tue, Nov 18, 2014 at 12:12 AM, Enrique Escolano escolano at cimne.upc.edu
gidlist-bounces at listas.cimne.upc.edu] *En nombre de *Shaini Dilsha
*Enviado el:* lunes, 17 de noviembre de 2014 17:46
*Asunto:* [GiDlist] Soil Modeling - Mohr Coulomb and Hardening soil Model.
Dear Sir/Madam,
analysis.
Yours Sincerely,
Shaini Dilsha.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141118/107fe4e4/attachment.htm
amit Dhankhar
[GiDlist] Fwd: Meshing curved volumes
Hi Enrique,
Would you suggest trying out some other version for GID for the meshing
issue of the curved geometry I created?
Thanks!
arc and a line)-
Amit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141117/f2834b18/attachment-0001.htm
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141117/f2834b18/attachment-0002.jpg
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141117/f2834b18/attachment-0003.jpg
I rebuild your shape avoiding the parametrization problems of your model and it could be meshed without problems.
You have created the extruded surface rotating a curve 180º that cross the rotation axis,
I created the same shape, but dividing the curve and deleting half part, and rotating 360º.
If fact it will be less problematic creating two surfaces not closed (with a rotation of 180º and multiple copies=2 in the copy window)
And the lower plane will be less problematic creating a planar surface by its boundary, avoiding the creation by rotation
(the poles of a surface of rotation are problematic, because this degenerated points have zero derivative in one parametric direction)
Enviado el: lunes, 17 de noviembre de 2014 18:52
Asunto: [GiDlist] Fwd: Meshing curved volumes
Hi Enrique,
Would you suggest trying out some other version for GID for the meshing issue of the curved geometry I created?
Thanks!
I tried the repair geometry option which just says "everything was ok" but fails to mesh. I created my volume by rotating a 2-d curved surface about its own axis. (which retains the original 2-d surface and creates extra points and lines which I have to collapse later)
I have attached a zip file containing the simple model - "nov13_curvedvol_original.gid" - volume created by the rotation which GID fails to mesh. Could you tell me what else could be wrong in this one? I am running 12.1.1d version of GID.
In another attempt, "nov13_curvedvol_mod.gid" - I wanted to get rid of extra surfaces, lines and points so I deleted the original 2-d surface and the extra lines and tried reconstructing the volume which gives out an error. This file just has the curved surface and it's base surface (which ideally should represent a bounded domain)
On Mon, Nov 10, 2014 at 12:26 PM, Enrique Escolano escolano at cimne.upc.edu wrote:
Inline image 1
Inline image 2
Amit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141117/a50bbea9/attachment-0001.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141117/a50bbea9/attachment-0002.jpeg
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141117/a50bbea9/attachment-0003.jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141117/a50bbea9/attachment-0001.obj
